Question about Gateway GT5404 PC Desktop
I have an VGA adapter on the cord b/c 15 pin male/9 pin female is almost impossible to find. Anyway when I connect to two monitors to the pc only on monitor comes on the other does nothing. comfirmed both work fine. What am I doing wrong?
  • Gateway Master
  • 5,660 Answers
Http://www.amazon.com/Female-HD15-Male-Adaptor-Molded/dp/B000I97FGA/ref=sr_1_2?ie=UTF8&qid=1352480644&sr=8-2&keywords=9+pin+female+connector
9-pin female to 15-pin male RS232 adapter
This = NO
http://support.gateway.com/s/PC/R/1009371/1009371rv.shtml
You cannot run dual monitors off of the motherboard.
BIOS will assign only one IRQ.
(Interrupt ReQuest )
That 9-pin connector (C) is a Serial port. This = No
http://support.gateway.com/s/PC/R/1009371/1009371rvr2.shtml
http://en.wikipedia.org/wiki/Serial_Port
You need a graphics card.
Don't be thinking of one monitor to motherboard, and one monitor to graphics card.
One IRQ, and it's assigned to either the -> motherboard graphics (Integrated), or a -> dedicated graphics card.
Two monitors to graphics card.
I am using a lesser model;
ATI Radeon 9250, and it's a PCI graphics card.
Goes in a white PCI slot.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5247980&CatId=1603
My PCI-Express graphics card gave up the ghost. (8 years old. It's cool)
I replaced it with the Radeon 9250 so could run dual monitors again.
Does fine for on here, Adobe Photoshop 7, YouTube, etc. Not a gamer.
(I have a Powercolor HD5450 PCI-Express graphics card I'm going to use, when I get off my duff, lol! Requires a 400 Watt power supply)
I use an HP 2009m 20-inch widescreen, as my Primary monitor, (Left side of computer desk), and a Philips 26-inch HDTV as my Secondary monitor. (Right side of desk)
Do you have two VGA (CRT) type monitors, or is one a flat LCD screen digital monitor?
Some flat LCD screen monitors have dual hookups.
One for a VGA cable, and one for a DVI cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If you have two VGA monitors that are the CRT type, (Looks like a small TV), and your graphics card has 1 VGA port, and 1 DVI port, they make a VGA to DVI adapter. Just make sure you get the correct one.
VGA port on graphics card is Female.
DVI cable connector is Male.
This is the usual standard.
This is the type of VGA to DVI adapter that is required,
http://www.directron.com/dviadapter.html
ALWAYS, install the software off of the Installation disk that comes with the graphics card -> FIRST
Install the drivers, and the user control panel.
(Driver: Small piece of software that allows the Operating System to communicate with a device.
The graphics card is the device, do not know what version of Windows you are using.
User control panel = ATI - Catalyst Control Panel. Nvidia - Nvidia Control Panel )
Do Not worry that you will loose graphics, after installing the graphics card software. Windows will Not use the software until THAT graphics card is installed.
Then after finished close all windows, go back to your desktop screen, and turn the computer off.
Unplug from power, FOLLOW Anti-Static Precautions, and physically install graphics card.
(Need to know about Anti-Static Precautions please post back in a Comment)
Set your main, or Primary monitor on the left side, Secondary monitor on the right; of your computer desk.
Turn the monitors on. If a CRT type allow them to warm up.
Turn the computer on. Once Windows has loaded your desktop screen will be on the Primary monitor.
1) Right-click on an empty area of your desktop screen
2) Left-click on Properties
3) Left-click on the Settings tab
The blue No.1 monitor icon is the Primary monitor
The blue No.2 monitor icon is the Secondary monitor.
4) Left-click on the Secondary monitor icon.
5) Left-click in the empty square box to the left of -
Extend my Windows desktop onto this monitor
6) Left-click on Apply at the bottom right
7) Left-click on OK at the bottom left.
Your desktop screen will now be on both monitors.
(Advisory comes up asking if you wish to keep settings? Yes)
Open your internet browser.
Move your mouse cursor to the Right side of the blue frame/border.
WHEN your mouse cursor turns into a Double-Headed Arrow, hold the Left mouse button down.
It is a little tricky to keep the mouse cursor as a Double-Headed Arrow. Must be that, and then hold the left mouse button down.
Holding the left mouse button down move your mouse to the Right, and drag the blue border of the internet browser to the Right.
Keep dragging until it is all the way to the right side, of the Secondary monitor.
Now you have your internet browser on both monitors.
I run the internet browser on my Secondary monitor, (26-inch HDTV), and use the Primary monitor to look at computer functions, motherboard manuals, etc.
Or I move the internet browser to the Primary monitor, play music videos from YouTube, and use the Secondary monitor for Photoshop.
The world is your oyster.
So there you have it. You need a graphics card, and it has to have dual monitor inputs. (Ports)
Splitter cable thing? I wouldn't bother.
IRQ - http://en.wikipedia.org/wiki/Interrupt_Request
Buying a graphics card:
Depends on what you want to do with it for one.
You can see the simple stuff I do, doesn't require much graphics power.
(More than Integrated Graphics, though, and can't use dual monitors on Integrated Graphics)
The next concerns are what type of graphics expansion slot/s do you have, and how much Wattage (Power) the Power Supply has.
You have a 300 Watt power supply, unless it has been replaced,
http://support.gateway.com/s/PC/R/1009371/1009371cl4.shtml
(Scroll down; Power Supplies)
Your motherboard has 2 white PCI slots. If one is available it can be used for a graphics card -> Not recommended
Your motherboard has one Black PCI-Express x16 expansion slot, that is used for a graphics card, also.
It is right above No.1 white PCI slot.
Highly recommended.
(Gently Pull UP on the PCI-Express x16 slot -> Lock
It looks as though you press down on it, when installing, or removing a graphics card )
http://support.gateway.com/s/MOTHERBD/INTEL/4006158R/4006158Rnv.shtml
So when looking for a graphics card, look for PCI-Express graphics card, and system requirements / minimum power requirement; states 300 Watt power supply, or greater.
For additional questions please post in a Comment.
I know that is a lot to take in all at once. I can clarify anything you need clarified.
Regards,
joecoolvette
Posted on Nov 09, 2012
SOURCE: Connecting Laptop to LCD
the following connections available to connect ur computer to an TV:
S-Video output: If you have video card(external u will have this), you require an s-video cable and you connect s-video out of your computer to the s-video int of our TV.
TV-OUT: if you have video card(external u wil have this) you you require an coxial cable and you have to connect TV-out of your computer to TV-IN of our TV(it is place where cable connection goes from your cable operator)
DVI-D: if you have video card(external u will have this) you require an DVI-D cable you haveto connect DVI-D out of your computer(a white 15-pin port which looks like VGA port) ....
VGA: it is the port on your computer which is only used to connect to your computer but not to your TV or LCD(strictly)
Thanking you,
M. Sridhar
Posted on Dec 29, 2008
  • 400 Answers
SOURCE: My gateway gt 5228 has power boots up but I have
First disconnect any external devices like printers etc that you might have plugged in.
If that doesn't work then it's a problem inside the box it can be the power supply ,motherboard ,memory ,CPU and others.
If the PC has warranty then you should take it back.
If you are comfortable in opening your computer then we could try more advanced troubleshooting ,let me know if you want to try it.
Posted on May 06, 2009
rasengan79
  • 138 Answers
SOURCE: My Gateway GT5404 PC won't turn on. Yesterday it
Try cleaning the RAM as shown in the image below:
If problem persist, replace the RAM. Hope this helps.
Posted on Oct 18, 2009
  • 41 Answers
SOURCE: When I turn boot up my gt5220 the monitor briefly
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Posted on Dec 02, 2009
SOURCE: I have a Gateway GT5056, no monitor will work.
buy a pci-e 16x compatible video card and install it!
Posted on Apr 10, 2010
VGA cord mag 786N monitor has 9 wires fat wires light blue pinkand whitethen six regular wires orange brown yellow white green and black in what order do they connect to 15 pin male vga adapter
Sweet, looks like something that I'd being doing. Here is one of my schematics for the pin lay out..
26141804-rnsaswimapvq3myhs3omkq3y-2-0.jpg you might need to fiddle with the Vertical / Horizontal Sync wires to figure which are which. Hope this helps FixYa issue..
Have a great night..
Mar 26, 2016 | Computers & Internet
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
Gateway GT5404 - Having trouble adding dual monitors
You have activate both monitors in display to view them at the same time.Look in your GPU setting to setup both monitors.
I can help live free here ! http://www.ezsystemrepairs.com/
Nov 09, 2012 | Gateway GT5404 PC Desktop
Install external monitor from desktop to laptop
If your laptop does not have the 15 pin plug (VGA Port) then you will need to get some type of adapter that will make the monitor work. You probably have a DVI monitor.
You just need to make sure you get the correct type of adapter and make sure the ends that plug into the computer are correct such as male or female. For example think of the human male and female body parts when you look at adapters. The vga port on the computer is called a Female port, but the piece that plugs into it is called Male. It's the same with DVI ports.
I think you need a VGA Male to a DVI Female so below is a link to one and for $2.54 from Cable Wholesale.
http://www.cablewholesale.com/specs/dvi-to-vga-cable/30dv-05300.htm
Below is a picture of what it looks like.
Jun 03, 2012 | Dell Computers & Internet
How to install external monitor to laptop if laptop does not support 15 pin plug from monitor
Jun 03, 2012 | Dell OptiPlex 780 Desktop Computer 1 x...
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
If this is the monitor cable you have, you need this type of adapter,
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
May 14, 2010 | Computers & Internet
Can't connect my emachine to 50" samsung plasmatv mod#pn50B530S2F
try going to "display properties" and adjusting the settings there. Right click on the desktop wallpaper and go to properties, then click on the settings tab. Make sure the TV setting is turned on
Mar 28, 2010 | Acer Aspire L100 PC Desktop
Gateway GT5404 PC Desktop Logo
107 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
