Question about Panasonic BTS Panasonic KX-T7730 White Hybrid System Corded Telephone
How to program name and extension - Panasonic BTS Panasonic KX-T7730 White Hybrid System Corded Telephone
  • 90 Answers
Press PROGRAM ** (then system password default is 1234) Use volume key to shoe extension name in display Use ENTER and ARROW keys and ALPHA NUMERICAL entry to change Press STORE to complete
Posted on Nov 06, 2013
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
Panasonic kx-t7730
What are you using to program.
PT Programming or you are using a PC Tool?
Did you save after setting names?
Jan 02, 2014 | Panasonic BTS Panasonic KX-T7730 White...
PANASONIC KX-T7731 PHONE I HAVE MY EXTENSIONS PROGRAMMED BUT I NEED TO CHANGE THE NAMES FOR EACH EXTENSION AND I CANNOT FIGURE OUT HOW. THE PREVIOUS SECRETARY HAS BEEN GONE FOR 3 YEARS BUT HER NAME STILL...
I"d start by pressing the Caps Lock button on my keyboard to ask a question and use that key marked Shift to capitalize the first letter of a sentence and proper names.
Extension names are programmed in SYSTEM programming. Access to that is done from the phone connected to the first extension in your system, usually 101, with a system password. In a TA Series, it's program 604. In some others, it's program 004.
Carl
May 24, 2011 | Panasonic KX-T7731 Corded Phone
Hi, I have this particular phone as my work phone, The extension name is "craig" which comes up on the screen, This was the previous guy that was here before me. How do i change it to my name?
This is a program, you can do this from extension 101
1. go to extension 101
2.lacate program code 604
this is the program number for the extension name
any doubt please contact again
Hope this helpful
Apr 20, 2011 | Panasonic KX-T7633 Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Nov 09, 2009 | Panasonic KX-T7636W Corded Phone
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
press the left hand intercom button
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
Oct 19, 2009 | Avaya Corded Phone avaparp18d
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Lucent MLX-20L Extension Edit
http://dstech1.com/changing-the-name-on-an-extension/
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Dec 22, 2008 | Lucent Merlin Legend MLX-10D Phone
Programming extensions
By default a TDA user has access to the first 9 programs in the Basic Programming (000-009). It lets you set things like date and time, speed calls, extension name, number and PIN code, and operator extensions.
Access to the programming is from an allowed phone by PROG **1234. You may have to consult your installer/dealer to find out which phone does that, but generally it's the operator.
Carl
Sep 09, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic BTS Panasonic KX-T7730 White Hybrid System Corded Telephone Logo
81 people viewed this question
Top Panasonic BTS Lands Phones Experts
Are you a Panasonic BTS Lands Phone Expert? Answer questions, earn points and help others
