Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
Posted on Jan 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no idea where this is.
  • patrickcrosb May 15, 2009
    shows error 50 what does that mean
Anonymous
Level 2:
President:
  • Expert 8,637 Answers
  • Posted on Jan 25, 2009
Anonymous
Expert
Level 2:
President:
Answers
8637
Questions
0
Helped
2740990
Points
514
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 21, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1165
Points
I got this new printer,Brother MFC-665 CW All-In-One InkJet Printer and when i turn it on but keep showing on viewer : unable to init. 50, pls help. thank you
How can we fix when a mesage says unable to print 50?
paper jam or some sensor problem, clear the paper jam, or clean the sensor under the pump.
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
3helpful
Im getting unable to print 50 error on my brother mfc 665cw
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
I'm getting an error saying Unable to print 30
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place. This could have been damaged when a jam was removed.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
1helpful
Unable to print 30 or 50
the encoder strip is probably out of its socket. its a long mylar strip that goes from one side to the other, and goes underneath the printhead.
6helpful
3answers
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
2helpful
Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Norman Weimar
Norman Weimar
k24674
