Question about Mastercool MAS69788 Recovery, Recycle and Recharge Machine 69788
MY 69788 RECYCLER MACHINE IS LOCKOUT, HOW CAN GET A FILTER CODE TO RESET
Keyless fob lock out
Alarm System Operation & Diagnosis - Range Rovers
www.rangerovers.net/repairdetails/becm/alarm.html
(If done by the key, a press on the remote locking button is still required before .... the BeCM goes into a 10 minute lockout mode (30 minutes for 1996 and later ..... buttons at the dealership, you may need to reset the code on the fob - which is ...
How to reset the security lockout on a Saturn Vue
www.kittycatonline.com/.../How-to-reset-the-security-lockout-on-a-Satur...
Nov 30, 2014 - How to reset the security lockout on a Saturn Vue. ... Now, though, not only does the "phone start" system still fail to function, the remote start fob now fails to work as well. ... the Passlock system starts out in what I'll call "agressive" mode. ... basically disabling it: Get the original factory remote unlock key fob, ...
Jan 08, 2016 | Cars & Trucks
Machine will not charge a system the tank is full the solenoid clicks but wont charge a system.
the solenoid is broken and it needs to be replaced, it also maybe a fuse with a relay unit all together in one unit. you will need a service manual,
www.manualsonline.com/
www.instructionsmanual.com/
www.manualsdir.com/
www.manualslib.com/
www.ask.com/
/mfg.name/make/model/service/manuals/dealers/parts/
Sep 18, 2015 | Mastercool 69788 Recovery/Recycle/Recharge...
How to i reset a station outgoing lockout code from XenMaster
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 05, 2012 | NEC Lands Phones
What are the carrier 8000ts led error codes?
They are listed inside the front panel of the main unit.
LED CODE
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST
DIGIT DETERMINED BY THE NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY
THE NUMBER OF LONG FLASHES.
STATUS
11 NO PREVIOUS CODE - Stored status code is erased automatically after 72
hours. On RED LED boards stored status codes can also be erased when power
(115 VAC or 24 VAC) to control is interrupted.
12 BLOWER ON AFTER POWER UP (115 VAC or 24 VAC) -Blower runs for 90
seconds, if unit is powered up during a call for heat (R-W closed) or R-W opens
during blower on-delay.
13 LIMIT CIRCUIT LOCKOUT - Lockout occurs if the limit or flame rollout switch is
open longer than 3 minutes.
- Control will auto reset after three hours. - Refer to #33.
14 IGNITION LOCKOUT - Control will auto-reset after three hours. Refer to #34.
21 GAS HEATING LOCKOUT - Control will NOT auto reset.
Check for: - Mis-wired gas valve -Defective control (valve relay)
22 ABNORMAL FLAME-PROVING SIGNAL - Flame is proved while gas valve is
de-energized. Inducer will run until fault is cleared. Check for:
- Leaky gas valve - Stuck-open gas valve
23 PRESSURE SWITCH DID NOT OPEN Check for:
- Obstructed pressure tubing. - Pressure switch stuck closed.
24 SECONDARY VOLTAGE FUSE IS OPEN Check for:
- Short circuit in secondary voltage (24VAC) wiring.
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than
five minutes, inducer shuts off for 15 minutes before retry. Check for:
- Excessive wind - Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Restricted vent
- Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used)
If it opens during blower on-delay period, blower will come on for the selected
blower off-delay.
33 LIMIT CIRCUIT FAULT - Indicates a limit, or flame rollout is open. Blower will
run for 4 minutes or until open switch remakes whichever is longer. If open
longer than 3 minutes, code changes to lockout #13. If open less than 3 minutes
status code #33 continues to flash until blower shuts off. Flame rollout switch
requires manual reset. Check for: - Restricted vent
- Proper vent sizing - Loose blower wheel - Excessive wind
- Dirty filter or restricted duct system.
- Defective blower motor or capacitor. - Defective switch or connections.
- Inadequate combustion air supply (Flame Roll-out Switch open).
34 IGNITION PROVING FAILURE - Control will try three more times before lockout
#14 occurs. If flame signal lost during blower on-delay period, blower will come
on for the selected blower off-delay. Check for: - Control ground continuity
- Flame sensor must not be grounded
- Oxide buildup on flame sensor (clean with fine steel wool).
- Proper flame sense microamps (.5 microamps D.C. min., 4.0 - 6.0 nominal).
- Gas valve defective or gas valve turned off - Manual valve shut-off
- Defective Hot Surface Ignitor
- Inadequate flame carryover or rough ignition
- Green/Yellow wire MUST be connected to furnace sheet metal
45 CONTROL CIRCUITRY LOCKOUT Auto-reset after one hour lockout due to;
- Gas valve relay stuck open - Flame sense circuit failure
- Software check error
Reset power to clear lockout. Replace control if status code repeats.
If status code recall is needed, briefly remove then reconnect one main limit wire to display
stored status code. On RED LED boards do not remove power or blower door before initiating
status code recall. After one status code recall is completed component test will occur.
Thanks for Choosing FixYa.
Kelly
Oct 05, 2010 | Heating & Cooling
How do you perform a manual reset on a 34788 cool tech filter replacement with filter lock out and no filter code accepted?
There is no way to reset without filter code. This machine ( Model-34788) will not accept even new filter code,if filter from old verson (manufacture before the machine). However try with this code-FD32C46B01. I'm sure this will work! Good luck & vote for my solution.
Aug 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi everyne PLEASE HELP ME i have a problem with
SORRY. YOUR MACHINES FUSER OVERHEATED CAUSING THE 502 CODE. YOU CAN NOT RESET THIS CODE IT IS A SAFETY
LOCKOUT. A SERVICETECH CAN RESET IT CHECK THE FUSER
AND GIVE IT A CLEANUP FOR ABOUT 200.00 IF FUSER PARTS ARE NEEDED IT MAY TOTAL 400.00
May 11, 2010 | Office Equipment & Supplies
I have two Electrolux Central Vacs. One is not working. Is there a reset button
If this is a CENTRALUX metal bodied 1590 series vac vac there is a reset breaker on the side of the motor housing of the vac. Depending on the age of the vac there is also a filter lockout switch . If you are using a cartridge filter and it is misaligned and drops down the switch will shut the vac off to prevent motor damage. Check those two items. The internal filter must be fully inserted so its twist lock/washer device can rotate holding it up in place. Then take a pair of insulated pliers and short across the low voltage terminals where the wiring system enters the top of the vac . If the vac starts, it is fine. If not your problem lies in the motor , the relay or the filter lockout switch.
If you have a plastic bodied Electrolux, a recent model the test procedure is the same but there is not the same lockout for the filter
Next test the nearest inlet in the house. If it fails to start you have a break in your internal wiring, possibly at a connection or a an inlet which may have a loose wire connection behind the wall. Post back with your results and if you have more questions. If so post the model #
Oct 28, 2009 | Electrolux Central Vacuum
Lockout code
you need to tell me what carrier you are with
May 27, 2009 | Samsung SCH-R400 Cellular Phone
My Maytag refrig. water dispenser & ice maker has ceased to work
there is a "control lockout" feature on the newer dispensors, ( not controlled by you(there is a control lockout feature)but I dont thinkn this is your issue.. the control lockout has somehow sensed a flood of water and for safety reasons has shut off the dispensor, the only way to reset this is to reset the control module, . You can either call for an autorized servicer to come reset, or if you feel up to it there sould be a trouble shooting/tech sheet taped to the underneath of unit, in the front right corner(behind hte kickplate)..
Jan 10, 2009 | Maytag Refrigerators
Mastercool MAS69788 Recovery, Recycle and Recharge Machine 69788 Logo
112 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
