How to fix white out tape when ripped
It is a whiteout tape that when you press on it on anything the whiteout will stick on it
Remove tape from car tape deck
tape, you have working tapes in 2013, wow?
i'd send em to the Smithsonian inst. LOL sorry!
done vast numbers. (wish not)
can be 2 things.
eject failure
or munch failure.
both require, lid off deck.
the capstan drive can eat any tape, for sure old taps and 2x that
dirty
if the tape is not wound around the capstan, then its not munched.
and is a simple eject failure,
gota love tapes... '
a better solution is a new head.
with USB port.
rip the tapes to MP3 (on any PC for free)
then copy them to USB stick (files)
end life of bad tape H3LL.
Oct 13, 2013 | Buick Cars & Trucks
My Sony Cybershot DSC V1 viewfinder screen very briefly shows the taken image and this then quickly fades to a foggy whiteout which sometimes shows the ghost of the image taken. The same image shows when...
It is possible that the image sensor which is the CCD- charge coupled device is faulty and will need a replacement. However it is important that the OE part is required and so is best to take consensus with Sony spares and service.
Mar 14, 2012 | Sony Cyber-Shot DSC-V1 Digital Camera
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
When I turn on the calculator it turns on but ony a large black sort of checkered box appears
A checkerboard cursor indicates a full memory. Press 2ND MEM 2 to bring up the memory management editor, and start deleting unwanted items.
If that doesn't work, try a hard reset. Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Turn the calculator back on.
Jul 06, 2010 | Texas Instruments TI-83 Plus Calculator
White-line on my lap's lcd
It does sound like a problem with your screen. If you want to get it fixed, a good company called revivemylaptop have an offer on at the moment. (www.revivemylaptop.com)
Jun 08, 2010 | Acer Aspire 4720 Notebook
SONY TC-WR550z dual tape deck eats tape and doors won't open I hadn't used this unit in 5 year (it's 13 or 14 years old), and before it worked fine. I went to use it again last month (MJ "Thriller" tape!)...
I don't know anything about the "eats tapes". You can take out your tape fairly easily thought. All you need to do is
unscrew screws on the left and right side of unit
remove the cover
use a flat head screw driver to gently push down on a white lever on the side of the drive mechanism while pushing the eject button
Sep 13, 2009 | Sony TC-WR565RM Single Cassette Deck
Tape comes out of cassette when ejected.
Your VCR is "eating" tapes, this is a common problem. First, wind the tape up by sticking a penny or other rounded object into the white "gears" on the back of the tape (with the tape hatch open by holding down the small button on the left side of the tape) and turn either clockwise or counterclockwise. Then check inside the VCR for moisture and remove any and all moisture with a clean rag. Moisture can cause the tape to stick to the VCR's internal components.
Best of luck to you.
May 30, 2009 | GPX TVR950 VCR
"whiteout"
If the photo shoot out show white , the obscure (quality variation),and even horizontal line ( white lines), and so on over-exposure cases,even if the use of anti-tremor, set to default values are invalid,because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Jun 10, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
"DV IF" Flashing
To get rid of the DV IF flashing go to >menu>systems>DV control ...OFF. (page 63 in the instruction manual)
Mar 06, 2008 | Canon XL1S Mini DV Digital Camcorder
124 people viewed this question
jasbo
jasbo
