Question about Kenmore Elite HE4 Electric Dryer
Calypso washer has a ld error i need a couple more possibilities for resolving the issue as i have checked those already. just a list of possibles.
  • 318 Answers
Is the unit full of water or still have some water in it? if so this code is for a long drain. the drain pumps will get plugged up with lint and cause the failure code.
tip the unit back and take the bottom off. then you will see the pump. take off the hoses and also look inside the pump to see if it is plugged with lint and that will cause it to not drain completely.
Posted on Jan 08, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Why do i get a "ld' signal or a "co" message?
LD = Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display
I don't see an CO error. Here is a complete service manual for your washer. I am sure it will come in handy in the future. Look on page 46 for a list of the error codes.
Regards, Rich
Feb 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Calipso it fills but LD comes on and nothing
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops and ld flashes on the display
Hi
Thanks
Rylee
Aug 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I do not have an owners manual for my Calypso washer. What does the LD sign mean?
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
THE CODE LD IS SHOWING UP AND WASHER IS NOT OPERATING
Press stop, cancel twice to reset. The Ld error is when it takes longer than 5 minutes for the washer to drain and reset the sensor. You probably have a partially plugged strainer or drain line. To check the strainer, remove the kick panel at the front bottom of the machine. The strainer is ibetween the drum and the pump, being connected to the drum with a rubber hose. Open the strainer (caution, water!), and clean. If you did not find much in the strainer, clean the drain hose. Dump the contents of the drain hose into a bucket. If possible, run an empty losd with dth drain line pointed outside.
This should fix your issue!
Best regards, --W/D-- feel free to rate this solution...thanx!
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer error code problem
LD is long drain associated with two problems the drain hose install and the pump. Debris in the pump and a drain hose inserted too far will cause most of these issues.
Sep 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
