Question about Jeep 2005 Grand Cherokee Limited
Fuse not blown and bulbs not burnt out anyone know what can cause this? headlights, brake lights, blinkers, and reverse all fine too
    Top Expert:
  • Jeep Master
  • 35,654 Answers
The front control module turns on the tail lights (and the front park lamps).
The front control module also handles front and rear wiper operation
Posted on Nov 10, 2012
I have a 2009 Forester. the tail lights do not come on. The blinkers. brake lights and hazzard lights work. The headlights work. #16 fuse is not burnt out. What could the problem be? Thanks for your
have you checked the bulbs? do the front driving lights come on?
if the front lights come on but not the tail, then it could be that the bulbs are burnt
Dec 24, 2014 | 2009 Subaru Forester
What would cause a 2000 VW Beetle's headlights just to stop working? Everything was fine Wednesday. On further inspection we have found out that we don't have a horn, headlights, blinkers, windshield
recheck the fuses, use an ohm meter that"s the only way to be sure.
if the fuses are ok do the same with the head lights.
a blown fuse is the only reason i know of for such a sudden loss of all the things you mentioned.
hope this helps
g
Oct 18, 2014 | 2000 Volkswagen Beetle
My headlights, blinkers, and reverse lights still work but my brake lights, taillights, and dash light does not work. I have checked fuses, grounds, and the knob you pull to cut headlights on. Any other...
Make sure all bulbs are working. All blinkers, tail lights, brake lights etc. I know you mentioned most of these lights work, however it only takes one light to throw off several others. Trace wiring from each as far as possible to locate a possible break in the wiring (shorts). Also, check the headlights and make sure they are plugged in all the way (even tho they work). Also check all relays. One dirty connection can cause all sorts of problems. Jeeps also are known for their poor wiring and common electrical issues.
Aug 29, 2014 | Cars & Trucks
Deivers tail light/brake light do not work..reverse works..when i lock my car the lights flash except for that one and the drivers light..headlights work fine though.drivers headlight bulb connector looks...
Could be a broken wire at the socket. Sounds like a burnt bulb also. Sometimes a burnt bulb will do the same thing as you are describing. Once you get this fixed, all should work. If flashing to quickly, replace the flasher stat unit!
Sep 04, 2013 | Volkswagen GTI Cars & Trucks
Rear brakelights dont come on fuses and bulbs are fine rear window brake light works
If the high level brake light works, then the brake light circuit is fully functional.
Brake light bulbs may LOOK fine, but can still have failed. Often folks don't notice that one bulb has failed until the second one has blown; it's then easy to incorrectly assume that the fault is more complex.
Try replacing the brake light bulbs: if that doesn't work then please report back for additional options.
Sep 24, 2010 | 1999 Audi A4
When I turn on my right blinker, the side
most likely a bad ground in your electrical system; consult your local mechanic
Oct 06, 2009 | 1993 Mercury Villager
Left blinker light stays on solid when headlights are on
I have had this happen and it is rare, but I have had a filiment burn out in a two filment buld and short to the other filiment. It does happen and I think this might be your problem, the only way to find it is a visual inspection of each bulb. I am sure many people will think this is crazy, but I have had the exact same problem, I had the schematics, tested the circuits,etc. and them by accident found a stop/blinker 1157 bulb that had done this exact thing. I hope this helps you, check the bulbs in your headlights also.
Dec 27, 2008 | 1999 Chrysler LHS
No tail lights.
You need to test for power with a test light at the tail light bulb, If you have power it could be a bad bulb or ground. IF you do not have power then trace the circuit back to the light switch.
Mar 09, 2017 | 2004 Nissan Murano
Jeep 2005 Grand Cherokee Limited Logo
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
