I think I would check and see if the dryer vent tube is clogged or nearly clogged. It sounds to me like it is. Try this first, if its not, I will continue to try and solve this with you.
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
check the duct work going out of the house if it is clogged the clothes wont dry. Birds love to build nest in a open dryer vent and if you have any bends lint will build up get these clean and it should get you drying again let me know what you find bill
An easy way to check dryer function is to check the airflow on the outside of your home at the exhaust the vent. While the dryer is running, and hot, put your hand near the outlet. The air coming out should be hot and forceful. If not, there is most likely an obstruction, and the whole airway should be cleaned. Keeping the airway clean and clear can dry clothes faster and save you money.
Another possibility is the blower,(fan) which can become encrusted with lint, preventing it from moving air. This is much less likely, but still a possibility.
you need to check the dryer vent hole on the back of the dryer,make sure it's not blocked,also check the wall vent for the same thing,most of the time if there is a clogg it holds the moisture in the dryer and it take forever to dry,you can use a shop vac to **** out any clogged lint in dryer and wall ,then if you have a leaf blower put it on the wall side and blow it it all out.let me know how you do-mike
