Question about eMachines Desktop / AMD Athlon II X2 Processor / 4GB Memory / 500GB Hard Drive (EL135223E)
How do I remove the dvd recorder (drive D) - eMachines Desktop / AMD Athlon II X2 Processor / 4GB Memory / 500GB Hard Drive (EL135223E)
  • eMachines Master
  • 5,660 Answers
Rob,
http://www.newegg.com/Product/Product.aspx?Item=N82E16883114085
I would like you to click right on the main photo, under the eMachines logo.
This produces several views.
To the upper right 8 small views are shown.
Go to the second row, and one at a time, click on the Middle photo, and the photo to the Right.
This shows you that, facing the Front of the computer, the Right Side Panel removes.
Clicking on the photo to the Left, on the second row, shows the Back of the computer.
Little hard to see since it is Black.
There is a Philips head screw to remove, from the right Side Panel, and towards the Top.
It is to the left of the Top, of the grille hole vent area.
There is a Philips head screw to remove, from the right Side Panel, and towards the Bottom.
It is to the left of where you plug the power cable in.
There is a finger pull formed out of the back of the Side Panel.
Pull back towards the back of the computer.
May only slide so far, then is tilted out at the top, and brought out to the side, and removed.
Look at the Middle photo on the 2nd row again. There are TABS molded from the Front Cover.
Black in color just like the Front Cover.
One at the Top, one in the Middle, and one at the Bottom.
These tabs are Gently brought out, to the Outside of the computer.
They are just Eased out a little bit, so the hooked end on them clears the metal framework of the computer case.
(Don't get carried away or they may break)
The Front Panel is gently swung out a little to the Left, where it then removes.
From here allow me to present a video from HP, and replacing an optical drive. (CD/DVD drive),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00981303&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
There are many different styles of mounting the optical drive.
The above is one style.
Some just use Philips head screws.
Some have a green plastic piece, that the screws on the side/s of the optical drive, slide in a slot in the green piece of plastic.
There is a plastic 'arm lock' that is gently eased to the outside, and just enough so the screws will clear it, when sliding the optical drive down the slot, and out of the Front of the computer.
All I see are SATA connectors on the motherboard, and no IDE (PATA) connectors.
Therefore your replacement optical drive will be a SATA model.
This is an example of a SATA -> data cable, and it's respective connector on the motherboard,
Note*
Color does NOT matter
SATA connectors on the motherboard MAY be of different colors, or all the same color. (Black)
Different colors designate the SATA connector order.
SATA 0, SATA 1, SATA 2, SATA 3;
Or, SATA 1, SATA 2, SATA3, SATA 4.
The different order designations may also be silkscreened on the motherboard, close to the individual SATA connectors.
The Harddrive is usually plugged into SATA 0, or SATA 1.
Optical drives go to any of the rest of the SATA connectors.
(Or multiple harddrives in a R.A.I.D. configuration)
The beauty of SATA though, is that you can plug that optical drive into ANY SATA connector on the motherboard, and BIOS will find it.
Also note the L-shape in the SATA data cable's connector, and the matching L-shape on the SATA data cable connector, on the motherboard.
Cable only plugs in, in one direction.
A SATA data cable connector, and a SATA power cable connector, may have a Lock on the connector. Near where it plugs in, on the cable connector, and is squeezed down with the thumb.
Squeeze to install, squeeze to remove.
The SATA data cable connector, and SATA power cable connector, are usually a 90-degree bent Elbow, for plugging into the Harddrive, or Optical drive.
A straight-end connector is plugged into the motherboard.
Between a SATA power cable connector, and a SATA data cable connector, the SATA data cable connector is the smaller of the two.
A SATA data cable connector has 7-pins.
A SATA power cable connector has 15-pins,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
REMEMBER, power unplugged to computer, Anti-Static Precautions FOLLOWED.
If you do not know about Anti-Static Precautions, post back in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Nov 09, 2012
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: My brand new emachines el1352-03
1) Faulty Power On switch. (Located inside the plastic Power On button)
2) Faulty Power Supply.
Not to diss eMachines, but they're known for using low quality Power Supply's. Saves them money.
Your eMachines should still be covered under warranty. Suggest you contact eMachines Support for some satisfaction.
http://support.gateway.com/emac/options.aspx
If this is not what you had in mind, please post a further up in a Comment, as to how I may be of help.
Posted on Oct 07, 2010
Our LG RH397d/rh399d DVD / Hard drive recoreder will only turn on and display the Hallo message, and you can hear a clicking sound from in side. I have remove the power cord no change .
Your DVD drive is having a problem. When this recorder starts, it checks the DVD drive for correctness. If incase your DVD drive is has problem in the ejecting mechanism then this will prevent your HDD from working correctly. Take the player to service center and fix the drive
Dec 28, 2010 | LG RH177 DVD Recorder/HDD Recorder
How to fit new dvd drive in LG RH7796W DVD 250gig recorder? I've had a serviceman tell me that the 250g HDD needs replaced. I do not want to pay $300 I would sooner have a go myself. Thanks
Open up your LG Recorder. You should see the HDD on the left, the DVD drive in the middle and a circuit board on the right..
Now, look at the back of the dvd drive.. you should see a power connector and a standard IDE interface..
Remove both of those connections carefully. Remove the screws in the black bevels on the sides of the drive and slowly pry out the drive by lifting the IDE interface side above the main board and pulling it out while slipping out the black clips on top of the tray side..
Now that it is done, take your new dvd drive.. you may want to remove the faceplate or at least the plate from the tray ..(slide it upwards.. it should slip out ) .. Place it where the old dvd drive used to be.. do the connections and your good to go..
Before closing, Check to see if the drive is functioning. Close up.
I have swapped drives on my LG many times and even upgraded the HDD.. I have used mainly LG and sony drives..
Mine was originally shipped with 80GB some 3 years ago.. I had put in a 160 GB and now will be putting in a 250 GB as the other is already full and i like to keep those old recordings..
May 29, 2010 | LG RH1999H DVD Recorder/HDD Recorder
AVion DVD Recorder won't record
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Feb 28, 2010 | Avion AV-DVR100 DVD Recordable...
When I put in a new a recordable dvd disc in my RDR GX 300 it will format & then it says this picture can not be recorded, even though I have previously recorded the program on my DVR from Directv. I...
Feb 27, 2010 | Sony RDR-GX300 DVD Recorder
My LG RH177 does not read and write DVD-R anymore. DVD+R disks work well at the moment. Any idea? Thank you.
I have done this on over 50 players for my clients in the past. I use LG DVD roms and DVD writers for the DVD recorders, irrespective of brand.
Dec 08, 2009 | LG RH177 DVD Recorder/HDD Recorder
Is it possible to copy all the files from my dvd recorder to removable media such as dvd's or a portable hard drive? i would like to back up all the family albums etc
If you have a computer with a dvd writer, there is no need to use an external DVD recorder to copy discs. The DVD software on your computer will have a way to temporarily record a disc to hard drive then allow you to insert a blank disc for recording.
A consumer DVD recorder will not have this capability. There is usually no way to output digital files; the machines are intended for playback to a TV.
Oct 10, 2009 | Hitachi DV-DS160 DVD Recorder
DVD burner will not burn or finalize
Jun 15, 2009 | Lite On LVC-9016G DVD Recorder/VCR
RAM Disk won't eject
unfortunately, this unit is on system lock down due to massive main board failure. its kinda like a system protect mode. this can only be repaired by the manufacture or maybe an in house tech with knowledge of the board outline. i don't think this unit has an escape code for retrieving the dvd. hope that helps ya and thanks for using fixya:)
Feb 06, 2009 | Panasonic DMR-HS2 DVD Recorder
DVD recorder model DMR-ES30V
I know this is very late to reply, but here it goes anyway. The groaning sound if from the DVD disc slipping on the drive spindle. There is probably a buildup of particles on the rubber surface of the spindle, probably from the DVDs themselves. Remove the metal cover from the unit. Then remove the 4 screws from the top of the black plastic drive and lift off the top. Locate the drive spindle in the middle of the drive and carefully wipe the rubber ring surface on the top surface of the spindle. Use a clean piece of cotton dampened with alcohol. Then install the drive top panel and metal unit cover. You wioll need to repeat this periodically whenever the groaning symptom reappears.
Dec 18, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD locked in and door is not opened
For those users who just bought their machines, I would suggest warranty service. Roxanne2 should contact Philips directly with the seiral number, and they should be able to say which store they sold it to. That unit probably has a bad internal DVD writer drive.
The following solution should only be done if your machine is out of warranty unless you get permission from the manufacturer, as it will likely void the warranty otherwise:
Unplug the unit, disconnect all cables and move it to as static-free of an area as possible. Remove the cover, which usually means removing a lot of screws. Most DVD recorders have regular drives like you see in PCs. There is usually a tiny hole in the lower-right part of the drive that you can stick a small wire into, such as an unbent paper clip. You can then manually pull the drive open to get the DVD out.
Oct 29, 2007 | LG RH177 DVD Recorder/HDD Recorder
eMachines Desktop / AMD Athlon II X2 Processor / 4GB Memory / 500GB Hard Drive (EL135223E) Logo
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
