Question about Samsung 5.4 Cu. Ft. 11-cycle High-efficiency Washer - White
It washed the load, but wouldn't finish the cycle. Got error message E3. The book said to press the pause/start button. Did that. Did not advance to next cycle.
    Top Expert:
  • Samsung Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 09, 2012
SOURCE: Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Posted on Mar 21, 2009
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
SOURCE: My washing machine wont spin or move.
All fixed - it was the belt that needed replacing
YAY no need to buy a new one
Posted on Aug 25, 2009
  • 380 Answers
SOURCE: we get an e3 error message and we have no idea
It's an over load error. Don't put alot of laundry in the drum.
Copy and Paste from the service manual
- Motor overloaded due to too much laundry (Nonsensing)
- The motor hall sensor terminal is not connected.
- PBA fault
- The motor driving error from the PBA is weak.
: Unstable relay operation, etc.
This error
occurs when an
interference is
generated due
to too much
laundry, etc.
Posted on Dec 30, 2009
  • 6277 Answers
SOURCE: I have a Samsung VRT front load washer, it was
First is to empty the water out. This can be done by following my (complete) general guidance notes below for checking the drain motor lint tray/filter and the motor.
'nf' means NO FEED and what happened afterward indicates that the water feed control valve is malfunctioning, initially not opening for water to be fed but then sticking open.
So follow these notes, particularly those in capital letters, to find how to empty the washer, and to check the state of the filter which is needed on a regular basis anyway ;-0)
Next will be a call to a service engineer to sort out the suspect valve.Sorry ;-0(
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 01, 2011
What does it mean E3
The E3 error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. Here is a link that will explain it better. Hope this helped Tim
http://www.ehow.com/info_7998394_samsung-washing-machine-errors.html#ixzz2NOVVbzKg
Jan 02, 2017 | Washing Machines
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
Pause error unit will not wash
Hello cvaughn37_cv - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Nov 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Its flashing E3 and chiming. and stopped washing
Hi
E3 is an overload error and indicates that the washer motor is not running properly. You can take out some clothes and then restart the cycle by pressing the START/PAUSE button. After this, if the error appears again then check the motor connections, if everything appears fine then the motor should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Maytag MAH6700AWW Neptune Front-Load...
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
F27 came up nearing the end of the spin cycle and just stops after it's spun but doesn't finish and release.
Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle. If it doesn't work, it means that the valve at the water entry needs to be replaced..
Hope this helps..
Jun 10, 2011 | Siemens WFXD8400UC Front Load Washer
Washing machine saying 3e starts a cycle then it stops and flashs 3e
The "E3" error indicates that a washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
A 3e error is a possible drain clog,Remove drain line and check for any clogs.
Apr 25, 2011 | Washing Machines
My front load washer goes into pause two min after machine is started i have to press start for cycle to continue and sometimes it does it a second time press start again it will then finish cycle
you should check button start / pause the washing machine, if it is damaged you must replace it with a new one, the damage caused by the push button which is not connected properly.
Aug 11, 2010 | Frigidaire ATF6000ES Front Load Washer
What does error code E59 means on a Frigidaire Affinity front load clothes washer?
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Apr 22, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Samsung 5.4 Cu. Ft. 11-cycle High-efficiency Washer - White Logo
66 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
