I have a whirlpool thin twin model number lt5000xvlno. I want to know how many amps are required to operate the dryer on its own? That is the amperage for only the dryer not the total amps listed on the appliance which is the amperage required to operate both the washer and dryer simutaniously.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Normally the dryer would draw about 22 amps on each side of the power lead.
Posted on Nov 09, 2012
  • 10 Answers
SOURCE: Whirlpool Thin Twin
Before you run in there with a hammer, is there any way to simply turn off the buzzer alert? I have a different dryer, but I can disable the buzzer. Please check the operator's manual first. If you've gotten to the point of no return, you can disable the buzzer - carefully. Never leave any exposed wires dangling about.
Posted on Mar 16, 2008
  • 15 Answers
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
agitateme
  • 88 Answers
SOURCE: Whirlpool Thin Twin washer/dryer
Check the lid switch, the machine will not spin or drain without the lid switch being activated. You should be able to see if the switch actuator is broken or missing, look in the slot where the lid's plunger drops into, if you can see the gray plastic actuator, set the machine in the spin cycle and try to depress the switch with a flat screwdriver, if it runs, the switch is cracked and needs replaced, if the actuator looks fine, and you can hear a distinct "click" when you press down on it, it may be a problem in the timer, but check the lid switch first, that's most likely the problem.
Posted on Sep 18, 2008
SOURCE: whirlpool thin twin washer dryer
How do i stop the loud pounding noise on the spin ,ajust the balance???or what else,i think the women that first used it put 2 heavy rugs and threw it out of balance?
Posted on Oct 25, 2009
What is the easiest way to access the dryer baffle to tighten them
Hello Jim;
My name is Peter. I am a retired field service appliance technician.
Dryers do not have baffles. Open the dryer door and locate the model number, then go into the following website and put in your model number to get a diagram of you dryer parts. Water Filters Lawn Garden Appliance Parts
Jan 30, 2016 | Whirlpool LTG5243DQ White Thin Twin 24"...
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
Dryer not working on Whirlpool Thin Twin
Could you check that model number again?Could you please describe the problem you are having?
Does the dryer run at all?
Check the door switch. When you push and release it you should hear a click. If not, replace with a new switch.
Oct 17, 2012 | Whirlpool LTE5243DQ Combination...
After replacing the heating element in lte5243dq the thin twin dryer it still doesn't work
http://www.partselect.com/ModelFrames.aspx?ModelID=706288&ModelNum=LTE5243DQ0&mfgModelNum=&ManufactureID=3&Selected=AJ4UQMWK&Position=4&mfg=Whirlpool&Type=&Mark=3
Did you check the thermostat and the high limit thermostat. If not check them for continuity with a volt meter to confirm if they are good or not. Continuity good, no continuity bad. I posted the diagram above so you can locate the pieces in the machine.
Jun 20, 2012 | Whirlpool Dryers
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Our Whirlpool Thin Twin model#LT7000XTWO will not start when pressing on the start button.Washer works.Could the problem be the starter button or the timer switch? Thanks, Ernie C.
Hello birddog44,
Happy to help you.
You said, Our Whirlpool Thin Twin model#LT7000XTWO will not start when pressing on the start button.Washer works.Could the problem be the starter button or the timer switch?
If the washer works, I can only assume, you are talking about the dryer not starting when you press on the start button.
I believe that it just might be the start button.
Is it a gas or electric dryer?
You have the Whirlpool Thin Twin model#LT7000XTWO
How old is this appliance?
The model # sounds like an older model.
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You,
huuum
Please give me a solved rating for this good advice
Sep 14, 2008 | Dryers
Whirlpool Thin Twin
Mar 16, 2008 | Washing Machines
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
