Question about Lexmark T642 Laser Printer
T642 wont print unless I cycle the power after a certain amount of time
Roughly around an hour it seems, I went to cfg to flash the printer and it calls for a .FLX file... I found the correct one on lexmark but I get an error 0x80004005 when trying to extract
  • r_marquis
    r_marquis Nov 09, 2012
    Its set up as a network printer in my home it just set up as basic as I could. If i print a now in about an hour my wife will try to print something and it wont print unless i cycle the power... I have been told all I need to do is flash with LSSTN234.FLX although when i d/l this from lexmark I get an error extracting it.
  • Official Brand Answer
  • 3,344 Answers
The error 0x80004005 is a permission issue in Windows. Try running the file as Administrator.
Posted on Nov 30, 2012
All Office
  • 58 Answers
SOURCE: Lexmark error codes
Too many to list here. Try justmanuals.com, you can get the service manual for about $10.
Posted on Jan 22, 2008
SOURCE: Lexmark t642
I too ran into this problem. Printer is about 2-1/2 yrs old.
Using it as a network device. I updated firmware from
a Mac OS X computer on the network.
a. Uploaded the firmware by going to lexmark site.
Do this first in preparation of upgrading firmware.
Follow instructions to get firmware update.
b. power cycle the printer (turn off & unplug power from unit)
c. power printer and turn switch back ON.
happily printer stays alive long enough to upload the new
firmware update.
d. Log on to your printer via a computer on your network
Open a browser, address will be your printer's IP address
or dns name. ex: http://192.168.1.3 (note: if you password
protected the account, you will need that info)
e. Follow menu to Configure -> Update Code where you will
"browse" to the file on your local computer (ex:
LSSTN234.FLX) and then hit the FLASH button
Posted on Feb 08, 2008
  • 3 Answers
SOURCE: Printer stops working until reboot
Could you provide an example of the commands you used?
Posted on May 15, 2008
SOURCE: Lexmark X 1270 Can not Print
I may be a bit late with this but it worked for me. Uninstall your antivirus, remove any parental controls and disable your firewall. Then, reinstall the printer and download a 2008 version of your anti virus and re-enable your firewall. I haven't reactivated the parental controls just in case it all goes pear shaped.
Posted on Nov 06, 2008
  • 14 Answers
SOURCE: Lexmark T642 Slow Slow Printing
I've had this problem with the Lexmarks's T640 printers connected via USB to Mac OS 10.5.5 machines.
Problem: The Mac OS' default resolution of 1200 DPI for this printer causes the printer to have to rasterize the print job again AFTER it arrives at the printer. The printer does a painfully slow job of this.
Solution: Change the default resolution of your print jobs to "600dpi".
Instructions:
1.)Call up the printer settings menu by starting a print job and clicking the up-arrow next to "Printer" box.
2.)Click on the drop-down list with the name of your application and choose "Printer Features".
Change your resolution to "600dpi". Oddly, I find that "1200dpi Image Quality" is almost as fast.
3.)It might be a good idea to "Save as" this new configuration in the "Presets" menu at the top of your list.
You should notice a tenfold increase in the time it takes the printer to actually produce print jobs now.
Additionally, in the "Color Matching" settings (you can get there by changing from the "Printer Features" settings), be sure that you are using "ColorSync" so your printer isn't having to do any additional processing in that area.
Posted on Dec 16, 2008
Konica Minolta 2400 laser printer has a slow, 52 times per minute, yellow lightning bolt flashing on its control panel on the front right of the machine. It seems to be locked up. It wont print or r
Sir bad idea to replace with partial one. Replace with OEM cart Brand New machine counts how many prints for several different parts in the machine when it reaches certain counts on certain part it wants NEW stuff.
Dec 18, 2014 | Konica Minolta Magicolor Model 2400w Color...
T642 getting a watchdog error with no other error codes
Hi, the way to fix this problem is by updating the firmware on your printer. Go to support.lexmark.com/printerfirmware and use the following keycode: lsstp240 that will download the firmware that you need to flash to your printer. To flashed you can do the following. If your printer is connected to the network then go to a browser and where you will type the Url (ex www.fixya.com) type the IP address of the printer. Then go to configuration, then go to Update firmware and browse for the firmware that you just downloaded and hit send. The printer will start beeping and saying updating firmware do not turn off. Once the firmware update is complete then the printer will restart and you should not see the watchdog error again.
Dec 30, 2009 | Lexmark T642 Laser Printer
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
Realign the print on my Lexmark T642 printer
You can adjust the print registration settings in the Config Mode of the printer. I believe you hold down both the down arrorw and right arrow button when you power on the printer
Jan 12, 2009 | Lexmark T642 Laser Printer
Apr 28, 2008 | Lexmark T642 Laser Printer
Black ink
Please try the following to resolved the issue:
Run a series of head cleaning
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START, CONTROL PANEL, PRINTER & FAXES then right click on CX3200 printer Icon then select printing preferences
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 02, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Lexmark t642
firmware update.
Dec 12, 2007 | Lexmark T642 Laser Printer
Sharing the printer over network
Can you print from the print server? If so that eliminates the drives. Are you sure permissions are correct?
Oct 30, 2007 | Lexmark T642 Laser Printer
Lexmark T642: Will not print text files in Linux
You need to download the Postscript drivers from Lexmark site.
Oct 28, 2007 | Lexmark T642 Laser Printer
Printing from Server applications
Is this printer set up as the default?
Try
file
Print
right click on the printer
go to properties
set as default
Sep 10, 2007 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
