Question about Dryers
How do I check continuity on timer switch ? - Dryers
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 09, 2012
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
I REPALCED THE TIMER CONTROL AND MY DRYER WILL
Always check to make sure you have power at the unit. If power is present and you replaced the timer control there is something else causing your unit not to fire up. I will assume your unit is an electric dryer. Before you check anything inside the dryer make sure your power cord is unplugged. Then check the door switch for continuity. If the door switch test okay then check the thermal fuse located on the blower assembly. Remove one lead and test for continuity, if okay then check the upper limit on the heating box. Again, this is a continuity check and again remove one of the leads before you check for continuity.
Sep 15, 2009 | Dryers
Won't start. No lights on front panel.
This could be a bad door switch. Check switch for continuity.
Also check for burned or broken wires on the door switch and on the timer.
The timer could be bad.
Hope this helps.
Aug 14, 2009 | Maytag 24 in. MDB4651A Built-in Dishwasher
Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Whirlpool Top Load Washer cycle problem
check the lid switch by putting a screwdriver into the lid switch hole; look at your timer duration diagram it's in the control panel a small sheet of paper taped inside Does you machine not advance mark the timer knob and, see how far the knob advances next set the timer for the agitate position and check the timer for continuity on those pins noted on the sheet
May 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
BUSH ID - HD TV
Try Checking your remote and make sure it did not short out by taking out the batteries and see if it continues turning on and off. if so then i would recommend replacing the remote. if this does not work try putting tape over the ir receiver and see if it continues, this will check for interference.
Nov 05, 2008 | Bush 5693D 24" TV
Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Sep 22, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
