Question about Acer Aspire One D257-13608 Intel Atom N455 1.66GHz 1Gb 250Gb 10.1 Wi
My computer has never been dropped or physically damaged but when i turn it on the screen looks cracked in upper left had corner,but it isn't really cracked at all. also there are lines running threw my screen.
  • Acer Master
  • 27,725 Answers
Could be a bad solder connection or a bad / dusty connection on some internal cable.
It could be a bad IC which functions as the controller to each pixel, but when you press on the monitor to fix it, that suggests it is a physical connection issue.
Test all power and data leads that attach to your hard drive SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
computers need power and data to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Posted on Nov 12, 2012
Emerson 37in flat screen Cracked inside out
Get what use you can, there is not a way to "fix" that--the front screen unit is called a display panel and even if it was available the part alone would cost much more than the whole set did when new, time to go shopping for a new set.
Sorry, damage to the screen unit is always fatal.
Dec 13, 2012 | Televison & Video
I have a hp dv6 laptop the inside of this screen looks cracked on the inside with ink leaks,outside is not cracked,i canot plug another moniter in as it says very faint in left corner windows canot...
If the screen looks like black ink on the screen then the screen is broken (ie cracked on the inside).
LCD screens and Inverters maybe available from this WEB site.www.lcdparts.net
Mar 11, 2012 | Computers & Internet
I dropped my dell notebook on the floor. The screen is 80% frozen however when I turn it off and reboot I can tell from the little corner I can see that the computer function but the screen stays stuck....
Try connecting an external monitor to your laptop via the 15 pin VGA connector located on the left side of the laptop.If the laptop display is normal on the external monitor then most likely your LCD (liquid crystal display) panel is damaged and needs to be replaced. The spider web effect is due to cracked display panel.
Sep 12, 2011 | Dell Inspiron 1525 Notebook
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Jun 15, 2011 | Computers & Internet
When i turned my camera on I got a large image of a crack expanding from the lower right hand corner of the screen. Most of the screen is black and the cracks are lit up white. There is a blue patch of...
Sounds like a cracked screen. My Rebel t1i looked the same way when i dropped it a month ago. Not sure of cost to repair i never looked into it but probably not cheap.
Apr 08, 2011 | Canon PowerShot G9 Digital Camera
I dropped my cell LG slide cell ph in a cup of
It looks like your screen was damaged after the drop.
You can try to replace the screen at a phone service center.
Thank you for using Fixya,
Kenneth
Feb 13, 2010 | Cell Phones
There is a shadow in the upper left corner of the screen
someone is going to have to look inside by either removing the rear upper part of the set or removing the entire front screen---neither is easy to do. But considering your trouble I would not be surprised if the mirror is cracked---the entire front screens would have to be removed to replace the mirror--special mirror and special handling--I have seen several break when someone is not careful putting in.
Aug 22, 2009 | Televison & Video
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
Acer Aspire One D257-13608 Intel Atom N455 1.66GHz 1Gb 250Gb 10.1 Wi Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
