Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Sony KDF-50we655 power light blinks red 3 times
I just replaced the lamp on my KDF-50we655 but now the power light blinks red 3 times.... what would this mean?
  • 2336 Answers
SOURCE: Sony KDF-50WE655 won't turn on.
if your TV blinks 10 times. Possible solution should be to check and replace on the G1 board Q1600 and Q1601 if shorted and R1614 and diode D1605 open.
Posted on Oct 20, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KDF-50WE655 will not power up. Red blight blinks 4 times
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Posted on Jan 27, 2009
SOURCE: Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
I fixed my problem by removing the lamp and vacuuming the hell out of the hole where the lamp lives and also getting all of the dust out of the rear ventilation grids with my vacuum. I put the old lamp back in and what do you know the TV has worked perfectly ever since. My lamp was over a year old and did not show any signs of hazing on the lens that you might see on a lamp that has a ton of hours on it. I just thought I would try to put it back in before I spent a couple of hundred bucks on a new lamp.
TA DA problem fixed.
Posted on May 05, 2009
welcomejee
  • 10594 Answers
SOURCE: KDF 50WE655
3 times blink means Lamp Cover is not placed back that was removed while replacing lamp, make sure lamp cover is fixed securely in its position.
Thanks.
Posted on Sep 28, 2009
SOURCE: I have a 4 year old Sony KDF-E42A10 television -
I Have a sony 50inch grand waga rear projection tv replaced bulb earlier on in the year i cannot reset the bulb program and now power light blinks 4 times sound but no picture can you help please
Posted on Aug 20, 2011
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
We Have a Sony KDF-50WE655, we've replaced the lamp and housing and we still have no picture or sound. Can you help?
Make sure that lamp cover is fixed back on its position securely after lamp replacement, turn On tv to check.
If still no picture or sound then check power/standby light is blinking?
If yes, count it how many times it blinks after 3 seconds long pause and let me know to diagnose possible cause of problem.
Thanks.
Aug 01, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Kdf-50a11e blink 3 time on red no images no sond when i start it the green lead blink many time then the red led blink 3 time and puse then 3 time
Three flashes indicates either the lamp is not seated correctly or the lamp door is not on properly. I bet its the later of the 2 as THE most common issue is the lamp door has warped because of excess heat building up in the lamp cage. If this is the case follow the link I am providing as you are in luck as Sony is paying for those repairs. Please take a moment to rate my answer...Thanks
http://esupport.sony.com/US/perl/news-item.pl?&news_id=261&mdl=KDF50WE655
May 18, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced the lamp and my tv still don't work
i have a sony kdf-50we655 tv and replaced the lamp. it still does not work green light blinks and then it powers down right away.
Feb 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Hi, i have a sony wega kdf-50we655. My tv just turned off for no reason after i turn it back on i waited and the standy by blinks green for a minute or so then it turn red and i notice the lamp indicator...
Yes. Be sure to push the new lamp housing all the way in until it's fully seated, and make sure you replace the access cover properly as well or the replacement lamp will not work.
Dec 04, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
KDF 50WE655
Thanks.
Sep 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Overheat issue on kdf-50we655 sony tv
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
this link tells about the blinking and how it's an self-diagnostic system that the tvs are programmed with. the number of blinks indicates the problem.
Jul 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
392 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
