Question about Coffee Makers & Espresso Machines
Im trying to take off the top cover to clean out the bottom of it
Put Vinegar threw
Posted on Jan 13, 2013
Cartridge is in but printer does not reconize it. How can I correct this? Was told need a new carriage, however printer is barely used. Will not pay any money to fix this problem. Will give printer...
Hello;
Try Reseatting the Catridges, follow the steps
* Switch on the unit and open the lid on the top cover
* Remove the Catridges from the printer
* Then just re-install the Catridges
* Then just close the unit lid or top cover
* After closing, cycle the power of the device by turning of the device for a few seconds
* Turn the printer back on
* Try printing a test page
If the before solution did not work, try the next one.
Wipe out the Catridge contacts
* Turn the unit on and open the lid or top cover
* Remove the Catridges,
* Use a clean cloth or a clean coffee filter to wipe the catridge. Wipe the catridge so briskly
to clear the waxy lubricants from the gold contacts.
* The contacts inside the printer may also require the cleaning. Use the clean cloth to wipe
from top to bottom of the contacts.
* Re-install the catridges and close the printers lid or top cover.
* Then try printing the test page.
If even the second solution didn't work try the last solution down
Perform a hard reset on the device
* Verify the unit is power on.
* Then unplug the power cord from the printer
* Wait 30 seconds
* Press and hold the power button in the front panel
* Plug the power cord back into the printer
* Open the top lid or top cover and reinstall the catridges
* Turn the device on
* Print a test page.
If the problem is unsolved, try replacing a new catridge.
Nov 03, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
Apr 18, 2010 | Vacuums
Im trying to get the door panels off my 1999 chevrolet silverado
There are a few screws which need to be removed, one under the map compartment (bottom of door ) one behind cover at door handle, once these are removed pry door panel out from the bottom up removing it from the clips, once this is complete lift up and remove entire panels off lip at top
Oct 24, 2009 | 1999 Chevrolet Silverado 1500
Cartrigde leaked ink to bottom of printer
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 18, 2009 | Office Equipment & Supplies
Replacing the skid plate on 07 Tahoe Z71
Remove bumper or use a swivel adapter to remove
Apr 29, 2009 | 2007 Chevrolet Tahoe
Ceaning inside of fan
With a little more detail on how to clean the 84001. There are 2 screws at the top of the unit on the back side and 1 on the bottom with a small removable cover. Remove those screws and the cover can be removed.
There will be some resistance towards the middle because of 2 clips on both sides. Be carefull not to pull too hard on the ends ; possibility of breaking the cover. Try pressing on center of the cover on one side of the edge.
There are 2 screws holding a bracket that holds the top of the fan. Remove those screws. Then on the bottom there is a shaft that attaches to the motor. You will find a set screw that you need to loosen. When you loosen and remove squirrel cage you will notice a flat spot on shaft. That is where the set screw is to be put when assembling the fan back together.
After cleaning just follow the steps back to assemble your 84001 and enjoy a clean brisk breeze. I hope this helps explain in more detail on how to clean it.
Oct 13, 2008 | Tower Aloha Breeze Fan
Kenmore bottom freezer keep freezing up.
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 13, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Sears Kenmore bottom freezer/refrig #68142model
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Im trying to replace the cloth bag on my Kirby G6. How do I release the belt that holds the cloth bag at the bottom of the assembly? It is grey and has teeth that grab when tightened on the bottom of the...
Kirby G6
Im trying to replace the cloth bag on my Kirby G6. How do I release the belt that holds the cloth bag at the bottom of the assembly? It is grey and has teeth that grab when tightened on the bottom of the unit.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There is a vinyl cover over the outside of the cloth bag and underneath the vinyl cover is a
ny tie that you have to cut off and replace with a new one and the cloth bag will slip off the bottom of the dirt cup @ the bottom of the cloth bag and remove the top cover and the bag should just come off, you can get the ny tie from any local vacuum cleaner dealer that does repairs or you can call the Kirby factory phone number listed below
http://kirby.com Contact Us
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Apr 16, 2008 | Vacuums
Water leaking from bottom and hose not connected
The hose just pushes on. You will have to take the top cover off to rehook up the hoses. There are scres on the bottom, then where the dirty water tank sits, there tabs that you have to unhook, then the cover will come off. Note: the filter inside the ditry water tank, leave a gap at the top to the filter. If you push the filter all the way up, it won't spray or suck up.
Jan 05, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Coffee Makers & Espresso Machines Logo
71 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
