Question about Whirlpool Duet GHW9150P Front Load Washer
How do I remove the drawer from the pedistal?
Do I have to remove the support rail from the drawer? (2 screws on each side)
  • mdscho Jan 08, 2009
    Sorry but there are no latches to release for these rails. I have looked and looked. I have seen the ones you mentioned on other applications but not on this. Thanks anyway!
  • 530 Answers
Usually when you pull the drawer out. look the the side of the trake you will see a black pointy thing you need to push one up and one dowm to pull out the drawer
Posted on Jan 07, 2009
  • erica graber Jan 08, 2009
    sometimes there are tabs that you have to push in. when you pull the drawer out see where it stops. that is usually where the tabs are. push in both seide and pull the drawer out
  • erica graber Apr 07, 2009
    or some have 2 1/4 inch screws if you open the drawer and look to the very left and right take those 2 screws out and the drawer you will have to pull up and off the rails
How do you replace a freezer drawer front?
The freezer drawer front is held onto the glide-out rails with screws on either side. These will be 10mm. Once the screws are removed you can lift the drawer front up and off the rails.Be careful when replacing to keep both left and right rails the same distance out from the cabinet so that they close evenly.
Sep 28, 2016 | Samsung 28 Cu Ft Black French Door Bottom...
Minolta di520 error code C0990
C990-C994 3rd drawer lift up and 3rd drawer elevator motor failure.Check the actuators and two motors .
Removal of the 3rd drawer:
1.Press the paper descent key and slide the 3rd drawe out to the front.If pressing the paper descent key does not allow you to slide out the 3rd drawer,insert a screwdriver or similar object trough the hole in the rear cover and unlock the drawer.
2.Remove 4 screws on the slide rails and pull the 3rd drawer out to the front.
3.Unplug 1 connector,loosen 2 thumbscrews to remove the connector board assy and remove the 3rd drawer.
4.Remove 4 screws,unplug one connector and remove the cover.
5.Remove two screws and the drive bottom cover.
6.Check the gears.
Aug 13, 2012 | Office Equipment & Supplies
We have a 22CF Refrigerator Model MFF2258VEM bottom Freezer, only 2 years old. It leaks Water once a day and it started about 3 weeks ago,on the left side onto the floor. We have shut off the water to the...
The problem your having is the defrost drain is blocked,to access the drain the freezer drawer must be removed then remove the back panel of the freezer,to remove the drawer pull it all the way out,look and find a phillips headed screw on the outer side of the slide rail near the door remove those screws(one on each side) lift the drawer off of the slide rails,remove rear panel and the drain will be under the evaperator coil(the stainless steel coil) BEWARE the fins on the coil are very sharp and will cut you. if you dont think you can do it call for service and tell them that the defrost drain is blocked.
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Maytag 21.9 Cu. Ft. Bottom-Mount...
How do you remove the sliding freezer drawers?
1 Open drawer to the fully out position.
2 Remove upper and lower baskets.
3 Remove screws one in each rail marked on side of rail.
4 Lift the front of the drawer up to remove the drawer.
5 Set the drawer on a soft surface to prevent scratching the
finish. If you have other questions please ask, Thanks Sea Breeze
Dec 14, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
How to remove bottom freezer drawer?
Pull drawer out. Remove one screw from side rail near door. Lift drawer off side rail supports.
Sep 25, 2010 | GE Profile PDS22SBSRSS
My bathroom drawer used to stay closed, but with pulling by my toddler, it now slides open on its own. How can I adjust or tighten to make it stay closed?
the track rails appear to have come loose. Remove the drawer place a level on the track rail and tighten or reinstall the screws which held it in place. There will be one set of screws for single track drawers or one on each side of a two rail drawer.
Feb 21, 2010 | ACCO Brands Kensington Desktop Comfort...
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Washer is off balance. Need to get to levelers.
I had the same problem...thanks for posting a solution. I agree with the solution posted above, but on my unit they are 1/4" HEX head screws, not phillips. Look at the illustration on page 4 here for help:
http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/XHP1550VB_Installation%20Instruction.pdf
I hope that helps.....
Dec 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Kenmore pedestal for the front loading elite washer and dryer
some pedistals have a screw on drawer just behind front on end of rail newer ones have a small black lever on each side ..pull drawer completely out lever is about midway at end of inner rail pull lever 1 up other down drawer will pull off rail reinstall by sliding rails back together and pusing all the way in
Jun 10, 2008 | Kenmore 15.5 in. Pedestal
Whirlpool Duet GHW9150P Front Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
