Question about Refrigerators
Refrigerator not working freezer works
Refigerator compartment stopped cooling but freezer compartment works perfectly
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 09, 2012
  • Dennie K Nov 12, 2012
    It is a Whirlpool ET19RK
dididsaythat
  • 291 Answers
SOURCE: refrigerator repairs
check freezer for frost build up on back wall and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Posted on Sep 04, 2007
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
rafaelrs38
  • 12 Answers
SOURCE: freezer and refrigerator stop cooling, back of
clean all the dust and form the gril on the back of your frig
Posted on Aug 10, 2009
woodchuck789
  • 4070 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
My Daewoo fr590nws is not cooling in the fridge compartment. the freezer compartment works perfect.
At a guess, I'd say the air channel between the freezer and refrigerator section is iced over. The easiest way to fix this is to switch off the unit, and leave it to defrost overnight. If the condition persists after this please repost your issue.
Dec 23, 2014 | Daewoo Refrigerators
Dometic R V refigerator model RM2611. Will not cool on gas or electric. The unit that has the filler plug on the end(Looks like a thermos bottle on its side) gurgles when supposed to operate. Unit...
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Jul 30, 2008 | Refrigerators
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
Freezer compartment works the refigerator part is not cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Refrigerators
Refigerator has no cold air freezer works good
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 21, 2010 | Amana AFI2538A Bottom Freezer French Door...
Refigerator is not cooling below 60deg, it is set at 44. The freezer works perfect (-2). the condenser had not been cleaned in a couple of years. I vacuumed it then used EasyOff oven cleaner on the...
sounds like your fan (in the freezer) has quit working. This fan is supposed to send cold air from the freezer to the refrigerator.
check and see if it's running.
hope this helps
Jun 14, 2010 | Sub-Zero 650 / O Bottom Freezer...
Freezer working but refigerator not...
Mullion heater is not the problem. If the refrigerator is not cooling look to the freezer compartment for your problem. Air from the freezer is used to cool the refrigerator(s) section. If the freezer coil frosts up it stops air circulation to the rest of the system. Although you may think the freezer is working properly it may have a defrost problem and will show up there also. Look for signs of frost on the back wall of the freezer as a sign of the coil freezing. The mullion heater is designed to put out just enough heat to stop condensation between the outside temperatures and the inner compartmant temperatures. If the inner compartment is warm the heater will seem warmer than normal.
Jun 26, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
