Question about D-Link DIR-615 Wireless Router
Wifi connection after reconfiguring the router my win 7 sees the router but will not connect. my win vista works ok. the win7 works ok attaching to another router.
  • 7,627 Answers
Do you need a password? In Network and Sharing go to Manage Wireless Networks, Do you se your SSID for your wireless access point? Hightlight and remove, reboot your laptop, you will have to choose your SSID and re-enter your password. If that fails do a cold start on your laptop: unplug, remove battery, hold on/off button 10 seconds, replace battery, plug in start normally.
Posted on Nov 09, 2012
XBRMann
  • 38 Answers
SOURCE: How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at http://192.168.0.1) and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Posted on Feb 10, 2008
tech curly
  • 298 Answers
SOURCE: Lost Wireless Connection DLink G604t
So if your other 2 laptops (WinVista) is working then that means that the wireless on your Dlink is working fine. Its possible that its a problem with the settings on the winxp laptop. does your winxp laptop have a builtin wireless adpater? What does it say on your winxp laptop is you will try to view the available wireless network?
Posted on Jul 29, 2008
manoline
  • 52 Answers
SOURCE: D Link model 2310
When you connected your PC directly to the modem, were you able to get the internet working automatically or did you have to run a dialup-like connection?
If it worked automatically, try this:
1. Connect a PC to a numbered port of the Dlink router (don't connect the modem to the router nor the PC)
2. Open Internet Explorer and enter http://192.168.0.1 on the address bar. This should then ask you to login. (restart the router and the PC if nothing happened then try again)
3. Enter admin for the username and blank for the password
4. Once you're on the Dlink Setup page, click on Network Settings on the left panel.
5. Change the Router IP address to 192.168.2.1 then hit Save Settings
6. Now, connect a cable from the Speedstream modem to the WAN port of the Dlink router then check if your internet is working from the wired PC.
If its still not working, turn off the modem and the router and then power the modem first (wait for the lights to be stable) then plug the router.
Hope this works for you. Goodluck!
Posted on Nov 07, 2008
SOURCE: wifi problem of DIR-300 dlink
Hi all,
Good day,
I have purchased a DIR-300 Dlink router. the connection is OK via LAN. the issue is the wifi I cant receive IP from the DHCP server of the router.
Kindly assist.
Qureshi
Posted on Jan 22, 2010
Techroy
  • 52 Answers
SOURCE: Intermittent internet disconnection, yet internet is fine
Please check the firmware of your router first. in most of the Wireless router the connection dropping issue is due to old firmware, also try chaning the wireless channel to 9 under the 2.4 GHz network to optimise the Wireless connection.
Posted on Mar 17, 2010
Reinstalling cisco m20 0n vista
Is it re-installation of complete network or you are just trying to add Vista computer to the network?
Is it a complete re-installation then you can reset the router to factory default settings and then try to reconfigure it.
You can run Cisco connect software on the main computer or you can also reinstall it manually,
Read how to reconfigure router manually,
If you trying to connect Wireless Vista computer to the network then you can simply search for the WiFi and then join the wireless network on Windows Vista computer
Jun 05, 2012 | Linksys by Cisco Cisco Valet Plus Wireless...
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Trouble printing from wired connections but wireless users are working fine
Its possible that in ap mode it cant handle wired and wireless and that the wired connection takes priority of the only available ip address, thus the wireless cards cant get an ip and so cant connect.
of course that could be b*****s but you never know.
yes i know you said it works fine when using xp pro so maybe the router doesnt release the ip correctly with win7.
any chance of installing a wifi card from one of the xp machines into the win7 machine just to test it?
can you test connecting one of the xp machines with wired and see if the other can connect using wireless?
So please You will have to reboot your router and all the wireless XP systems, while the Win 7 system is off. You may have to reboot the router once in a while. Not the most elegant solution, but this is the only way my XP systems with wireless would work.
Nov 03, 2011 | Adtran NetVanta 1335 Router (1700515E2)
I cant find the wifi password.
Connect Router to the computer or use a computer which is connected with router
1. Open Start - Run - CMD (To open command prompt, for Vista and win7 type cmd in search) 2. IPCONFIG and press enter 3. Make a note of Default gateway address (usually its 192.168.1.1 / 10.0.0.1) 4. Open Browser and type the default address(For e.g http://192.168.1.1) 5. Type username/password for router (usually you can find this info on bottom of the router) 6. Goto Wireless settings and there you can see your password and also you can change name and password (To change name edit SSID)
7. Save settings
Thats it, go to go now Hope this helps
Jul 06, 2011 | Zyxel P660HW-D1 Router
I installed windows 7 operating system in my pc. i have samsung pc studio installation cd for ony windows xp & vista. How can I work with win7 & connect my 3G mobile to my pc ?
YES IT SURELY WORK FOR WIN7 MOST OF THE SOFTWARE WHICH WORK WITH WIN VISTA THEY ALSO WORK FOR WIN7 BUT KEEP IN MIND YOU HAVE TO INSTALL PROPER DRIVERS FOR YOUR PHONE IF YOU HAVE DEVICE DRIVERS FOR YOU PHONE FOR WIN VISTA THEY WOULD WORK FINE. MOST OF TIME WIN7 AS A VERY CAPABLE OS MY AUTOMATICALY INSTALL THE DRIVERS FOR YOU DEVICE. THANKX
Feb 08, 2011 | Computers & Internet
Setup didn't work, "details" section on network
Win7 will connect without any problems, but win vista will not get connected to the network...
You can update the drivers for wireless adapter in vista laptop, it will get connected...
If it still not getting connected then change the security settings on your router to 64bit WEP... (Initially it will be in WPA)
disabled the WPS (wifi protected setup) in the router...
change the ssid in the router...
Now try to connect to the new wireless network...It will work perfectly....
click here to configure the wireless part of your belkin router...
Any issues call 18002235546 ( 24/7 )
Feb 06, 2011 | Belkin Play N600 Wireless Dual Band Router...
Can not get connected
Powercycle (unplug power) all your equipment, Modem/Router waite 15 seconds then plug back in. If you are having an issue with the ip address not valid you can try these steps
(win xp) Start/Run/Type ncpa.cpl hit ok, You will see wireless connection double click wireless connection this will bring you to the properties. ensure that the connection is assigned by DHCP also check to see if you have a valid ip address
Win Vista/7 Start/Search Bar/Type ncpa.cpl Right click on wireless connection and hit properties. Uncheck Internet protocol version 6 and click on Internet Protocol Version 4 and hit properties/Ensure that obtain ip address automatically is checked as well as obtain dns server automatically. hit ok close out.
Go to command prompt Win XP Start/Run/Type CMD hit ok
Win Vista or 7 Start/all programs/accessories/ right click on command prompt and hit run as administrator.
At command prompt type;
netsh int ip reset reset.log hit enter
netsh int ip delete arpcache hit enter
netsh winsock reset hit enter
ip config /flushdns hit enter and restart computer this will reset the ip address hope this helps good luck
Oct 01, 2010 | Computers & Internet
I keep losing my network connection with my D-link WBR 2310
Try upgrading the Routers firmware settings, before you do that make sure that you take down the settings , as you will have to resetup your network .
Feb 04, 2010 | Computers & Internet
Will d-link airplus xtreme G+ work on windows 7? I have installed from CD under win 7 but Dell Dimension cannot see it.
You might look for the latest version of the driver at the manufacturer's web site and install that version instead of the CD. If there is not a driver specifically for Win7 then I would try the Vista version. The driver interface to Windows had some changes in between XP and Vista, but not so much from Vista to Win7.
Dec 15, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cannot get internet and WiFi when I connect to smc6624M
ok you do the reconfigure the linksys routerand give the wireless enable in the both smc and the linksys also .
Jun 01, 2008 | SMC (SMC7004AWBR) Router
D-Link DIR-615 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
