Question about GE 27GT622 27" TV
Can't connect DVD player
I have tried to connect my DVD playe to my TV. I have all the cables connected to the TV but can't find the channel showing the DVD. How do I program the TV to show the DVD picture
What if u lost the remote
Posted on Apr 26, 2008
    Novelist:
    Champion:
  • 275 Answers
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
Posted on May 24, 2007
New dvd player wont play when I change channel to av. All plugs in correctly. I have an indoor antenna but get every channel. What is wrong?
Try a different channel on your TV Some times it may be AV1 or AV2 on the TV that you have to connect to. The DVD should also show a "start up" screen on the TV to show you that it has connected properly.
Apr 19, 2015 | Televison & Video
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
Our Emerson EWD7003 now only plays in black and white after DISH hookup
Does the Tv channels show colour? if yes! I would try another audio/video cable connection from the DVD player to the Tv and try another input to the set, to see if that will help.
Apr 25, 2012 | Emerson EWD7003 DVD Player
Our new Toshiba SDV398KC2 will not play a DVD. It is like it is on the wrong channel. It shows the DVD playing with the counter but does not show it on the TV. Can you help?
I've seen this behavior before.
For this model, I *think* that you need to use the component connections/input in order to view the DVDs. If VCR shows ok when using the cable, but not the DVD (and it seems to work since it goes up as if playing), try to connect the component (blue/green/red connectors) and it should work.
Don't forget to switch input on your TV to component.
P.S. If you have HDMI on both this dvd/vcr & your TV, it should work with that too.
Nov 18, 2010 | Toshiba SD-3980 DVD Player
Trying to hook up dvd player to a philips 27ps55-s121. I cant get it to show up on the tv screen. I dont know what channel the tv needs to be on to show the dvd. and i am unsure where what plug (cable)...
Connect one end of the VIDEO
(yellow) CABLE to the AV1 in VIDEO
jack on the back of the TV. Then connect
one end the AUDIO (red and
white) CABLES to the AV1 in AUDIO
L and R(left and right) jacks on the rear
of the TV. Connect the other end of the cables to the appropriate color on the DVD player (yellow to yellow etc.)
Press the CH + or – buttons on the
remote to scroll the channels until AV1
appears in the upper left corner of the
TV screen.
Slide the TV/VCR/ACC switch to
the VCR position.
Insert DVD into player and press PLAY.
Aug 23, 2010 | Philips Televison & Video
It says "play" and my tv is on Ch.3 but there is nothing playing. I tried turning my direct tv off but it made no difference.
do you want to record programs on your vcr? connect the out to tv cable from your dir/tv box to antenna or cable in on the vcr, then connect the cable from out to tv on the vcr to antenna or cable in on the tv, you'll have to select channel 3 on the tv to get the vcr to show a picture and you will need to select channel 3 on your vcr to record the channel selected on your dir/tv box. confusing?thanks and good luck.
Jan 02, 2010 | GoVideo Go Video DVD/VCR Combo
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Channel keeps changing to 'Input 2' even when playing DVD
Have you taken the remote control out of the room? Try changing inputs from the TV.
Dec 21, 2008 | Sharp 32F641 TV
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Televison & Video Logo
336 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
