Sony kdl32w5500 hdmi no input
Was using pc through tv via hdmi this morning when there was a blackout. when power was restored, there was no hdmi input through the television. have check all onscreen menus for a setting that may have been changed, but anything that looks like it may be of use doesn't work. there is nothing in the manual that covers this problem. have reset to factory default and run setup, but that doesn't work. can control devices through hdmi using the tv remote, just can't get picture and sound.
SOURCE: HDMI port not working
I have the same problem - its a HDCP handshake issue. Sony says the firmware in the Westinghouse TV needs to be updated - Westinghouse says that they have firmware updates for some models depending on your TV's serial number, otherwise they are working on firmware updates for the rest of us that should fix the problem. Call Westinghouse to see if you can get updated.
Posted on Oct 26, 2009
budmrtn
  • 11361 Answers
SOURCE: Sony Bravia KDL-V40XBR1, no picture
You either have failed 24vdc power supply section or failed backlight inverter board, check for 24vdc first, look for caps with leaking/bulging top.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sony+BRAVIA+KDL+-V40XBR1+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
eagle338
  • 4889 Answers
SOURCE: 47" two yr old Visio
This is the second time I have seen this problem this week. Seems like a common issue on Vizio LCDs. Anyways the problem you mentioned indicates that the tv-micro IC has failed. THis is located on the main audo/video board and a component level repair is not possible in this case. The main A/V board has to be replaced and it should cost you around 100-125$. Would you like to do it yourself?
Posted on Dec 29, 2010
  • 639 Answers
SOURCE: remote wont work and can't acess menu with tv
Turn your Sony Bravia on by pushing either the power button on the front of the TV or the power button on the remote control, which is located in the upper right corner of the remote.
  • 2 Press and hold the "up arrow" button on the remote control. The up arrow button is located in the middle of the remote, to the left of the "Input" button and below the "Picture" button.
  • 3 Press the power button on the TV while still holding down the up arrow button. The TV will turn off and then turn itself back on.
  • 4 Release the up arrow button. Once the TV turns itself back on, it will restore your Sony Bravia to its factory settings.
  • Read more: How to Reset a Sony Bravia TV ' eHow.com http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html#ixzz1Cn2noiTF
    Posted on Feb 02, 2011
    westytech
    • 120 Answers
    SOURCE: I think I set up
    Hello Jdreier520, I would be more than happy to assist you but would rather do it live. Please send me an email to westytech@westinghousedigital.com so I can better assist you. You can either provide me with a contact # or I can send you my contact information so you can call me at your earliest convenience. Please note I will need model #, serial #, and TW# all located on the back of the TV as well as what you have connected to the TV and how they are connected. Looking forward to helping you get your TV running in no time.
    Posted on Jun 24, 2011
    Automate On/off for longer than 6 hours and for HDMI input
    I would buy a inexpensive timer you can program to turn the TV off and on. Plug the TV into the timer on the wall outlet and Voila !
    Jan 30, 2014 | Sony BRAVIA Televison & Video
    How to activate my laptop to my samsung tv
    If you mean watch what you see on your laptop on your TV, then you need to connect an HDMI cable or S-Video cable (depending on what sort of ports you have) from your laptop to your TV, then select the appropriate input on your TV or TV remote. For example if connected via HDMI and your TV has 2 HDMI inputs (ie. HDMI 1 and HDMI 2), select which one you connected to.
    Jan 26, 2012 | Sony VAIO Notebook
    The receiver is hooked up via HDMI and after about
    user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
    Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
    I have a new sony laptop with windows 7 and sony XBR6. Trying to hook up the laptop to the tv via HDMI. The laptop can 'see' the tv and the inputs menu on the TV shows there is something connected to that...
    Hello. Do not use HDMI for this purpose, instead go to Walmart and get a usb cord that plugs into your tv. Then use the remote control for your TV to push input and locate your computer, usually at the bottom of the list. Regards, Joe
    Dec 22, 2009 | Computers & Internet
    I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
    Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
    2X HDMI cables and one Optical are required.
    Enjoy great sound :)
    OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
    Sep 04, 2009 | Yamaha RX-V363 Receiver
    Powers on - no output to TV
    Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
    Jun 20, 2009 | Sony Playstation 3 (PS3) Console
    Cannot connect ps3 to lcd tv via hdmi cable
    First off make sure ALL Units using HDMI are Powered OFF! Connect Cable, Then turn on all components. On the PS3 Crossbar (Menu) go to the 2nd column on the left, Then down to Display Settings. Choose Output Settings, Choose HDMI, Use AUTOMATIC. Then do the same with the Audio, HDMI, AUTO Make sure your TV is on the Right HDMI Input! Good Luck!
    Apr 25, 2009 | Sony PlayStation® 3 (80GB) Console
    No play back from HDTV to threater system
    Do you have set-top-box or antenna-cable directly to TV?
    You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
    You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
    But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
    But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
    Jan 25, 2009 | Sony STR-DG520 Receiver
    Periodic tv screen blackouts
    The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
    Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
    Televison & Video Logo
    46 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
