Question about IBM "Thinkpad X220 Laptop Lenovo, I7-2620M 2.7Ghz, Ips, 12.5 Premium Hd"
Turn off caps lock indicator windows 7 lenovo
An Icon displays on my screen when I press the CapsLk button. It will remain until I press it again to turn off CAPS lock. How do I prevent the icon from displaying. It is very distracting.
  • Michelle Ruth Kalas
    Michelle Ruth Kalas Nov 13, 2012
    This is not a web camera question.  I am not sure how it ended up in that category. Resolution:  1. Control Panel > Display2. Screen Resolution > Advanced Settings3. On Screen Display Tab4. Uncheck Enable on-screen display
LaptopExpert
  • 458 Answers
SOURCE: My ibm thinkpad booting and hanging fault
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Posted on Jun 09, 2008
cpenzes
  • 1102 Answers
SOURCE: Lenovo T60 - Can't get beyond the the bios password prompt
press your Fn key and either F11 at the same time
if this does not unlock then press Fn and numlk
key at the same time
please let me know
your unlock will be a combination of Fn and anothe colour code key at top of laptop
Posted on Feb 20, 2009
SOURCE: IBM T40 Laptop screen goes black, will not come back
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Posted on Mar 08, 2009
  • 14 Answers
SOURCE: Blank Screen
First, confirm that it is the screen itself. Connect the video output to a known working monitor and then power on your Thinkpad. if the known working monitor behaves the same way you can rule out the laptop's monitor as the source of the problem. This may be the BGA, Ball Grid Assembly, leadless soldering problem related to video chips on the motherboard, but first test the monitors.
Posted on Apr 18, 2009
sparky1500
  • 1066 Answers
SOURCE: Screen Won't rotate
you need to change your screen resolution to rotate, make it so that it is taller rather tan wider
Posted on Dec 27, 2009
Indicator Lights are Turned off
it shows that the windows may not fuctioning well, re-installtion is recomended, try to fix these issues from bios as well
Jan 28, 2013 | Computers & Internet
CANT TELL IF MY CAP LOCKS ARE ON OR OFF WHAT DO I NEED TO SELECT TO KEEP THIS FEATURE
if your caps light is on a light will/should show on your keyboard
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/numcapsscroll-indicator/3000-2072_4-10604212.html
On-screen real-time indicator showing the status of the Num, Caps and Scroll Lock buttons on the keyboard. NumCapsScroll Indicator monitors their status and indicates it in the System Tray with its icon, with a tool-tip when you mouse-over its System Tray icon, with a small On-screen Keyboard-like panel and a sound indicator. It's also an identical utility for laptops that are not supported with Num, Caps and Scroll Lock LEDs on their Keyboards.
What's new in this version: Version 7.0 is compatible with Windows 7.
Apr 06, 2011 | Computers & Internet
How do you reset the change oil soon display on a 2008 yukon after changing the oil? how many quarts does it take?
Hi. You have these 4 buttons in a row (DIC buttons) you can find it near the left of the center a/c vent.. Select the button with the car icon. Press on this button repeatedly until the "% OIL Life Remaining" appears on the IPC messages screen. Stop there. Press and hold that same button until the message indicate "100% Oil Life Remaining". With a new oil filter, around 5.6 liters. And that's it. Okay, sir? : )
Jan 04, 2011 | 2008 GMC Yukon
Installed AOC 2436vh, top of screen off of physical structure of screen, tried power down, physical reinstall, roll back of driver and reload of cd, how do I uninstall monitor to try again? Or adjust it...
I have the 2436V (no speakers), but I suspect the solution will be similar. My screen was a bit to the left of the monitor's physical display area, and I was able to solve it using the built in menu (If you take too long deciding what menu button to press next, the menu will time out. Just start over if that happens. You will get faster with practice).
1) Press the menu button on the monitor (the menu appears).
2) Press the up button on the monitor 4 times to highlight the icon that looks like a slightly angled screen with yellow cross-hairs in one corner (the toolbar for positioning the screen appears - all 5 icons on the positioning toolbar are blue).
3) Press the menu button on the monitor to "enter" the selected toolbar (one of the toolbar icons turns green to indicate the selected tool on the toolbar).
4) Select the tool you need using the up/down arrow buttons on the monitor (I needed the one that moves the screen horizontally, you need the one that moves the screen vertically).
5) Press the menu button on the monitor to activate the selected tool (the meter above the toolbar icon turns green to indicate the tool is active).
6) Use the up/down buttons on the monitor to position the screen.
7) Press the menu button to exit back out (or, just let the menu time out).
Note: the disk that came with the monitor doesn't seem to have drivers for Windows 7, but allowing Windows to search online while updating the driver found a compatible driver online.
Dec 22, 2010 | AOC Monitor
How to reprogram my Woods N1506 Timer
Manual and image for Woods/Noma N1506 outdoor timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
Timer is only set to nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Dec 13, 2010 | Woods Outdoor Lighting Timer
How to program my Woods N1506
FOR MANUAL OVERRIDE
Dec 13, 2010 | Woods Hardware & Accessories
How do I set my Woods N1506 timer?
According to another fixya answer posted December 4 2009:
FOR MANUAL OVERRIDE
Nov 23, 2010 | Woods Outdoor Lighting Timer
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
I need instructions for using my N1506 timer.
Plug in timer – The letter C will Flash
Press Time Button – It will advance to 1 a.m.
Press Mode button – Letter P will flash inviting you to set the program
Press Mode button again – the letter E now flashes.
Press time button – Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
FOR MANUAL OVERRIDE
Dec 04, 2009 | Woods Hardware & Accessories
IBM "Thinkpad X220 Laptop Lenovo, I7-2620M 2.7Ghz, Ips, 12.5 Premium Hd" Logo
1,381 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
