Question about Maytag MED9600S Electric Dryer
Interface control dryer - Maytag MED9600S Electric Dryer
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 09, 2012
What does F70 mean on a front load dryer?
Hello Carol;
My name is Peter. I am a retired field service appliance technician.
F70:
No communication between the electronic control board and the user interface control board assemblies.
Unplug the dryer. Check the wire harness connections between the main electronic control board and the user interface control board assemblies. If the connections are sound, have a technician diagnose the cause of the communication failure. The main electronic control board and/or the user interface control assemblies might need to be replaced.
Dec 06, 2014 | Whirlpool Dryers
What does an interface control do
The interface control tells the CCU what program to run.
Nov 09, 2012 | Maytag MED9600S Electric Dryer
Had F70 &F71 changed ccu and ui won't power up just beeps
Even after they replacing the CCU and the MCU, I still kept getting the three beeps and the F70 Error... the fix was replacing the front controller boards (where the knobs and buttons are). check your connections also, and that they are in the proper slot.
Oct 31, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
Error code f 40. dryer will not start
F40 code implies a possible loose wiring connection and if there are no loose wiring connections then the user's interface will need to be replaced. I added an image (click for zoom) below with instruction how to access the control board and the user's interface board. The user's interface is part #280157.
NOTE: Disconnect the power cord from the power source before servicing your dryer.
Parts can be looked up and ordered at Sears PartsDirect
Hope this helps.
Jul 27, 2011 | Dryers
Kenmore elite he3 dryer says PF
The PF and E2 (F02) error codes are related. The PF indicates that the dryer is experiencing a power failure. The F-02 error code indicates a Keypad/User Interface failure. The error codes for this dryer are shown in the third image below.
You could have a loose wire harness connection between the machine control board and the user interface control board that could cause there error messages and symptoms. The first image below shows how to access these components. I recommend that you unplug the dryer and then access these components. Check the wire harness connections on between the user interface control board and the machine control board. If the connections are okay then you will likely need to replace the user interface control board to correct this problem. The part number for the user interface control board is 8564396. You can order this part from the Sears PartsDirect website. It costs just over $100.
Sep 20, 2010 | Kenmore Dryers
Kenmore Oasis Elite gas dryer,beeping, flashes OF
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 01, 2010 | Kenmore 67082 Electric Dryer
When using dryer it stops and f70 shows up as problem id not listed in manual dori@dkcompanyinc.com
F70
CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no
communication is detected from the Central Control Unit to the User
Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
I have reseated the cable between the CCU and the User Interface panel (panel has the buttons & lights on it)
Mar 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Oasis Dryer
You can order this part from www.SEARSPARTSDIRECT.com
NOTE: You should only attempt this procedure if you are completely confident in your technical ability to safely execute the process.
Follow electrical safety guidelines. Unplug the washer before accessing internal components.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 09, 2010 | Kenmore 67082 Electric Dryer
Power will not come on to control panel. Door light comes on and the locked light comes on
Check and make sure you have proper voltage at the plug, reset yoru breaker.
Also are the led indicators dim (lights) on the interface board. Watch your terminology as there is a control board but it has no lights on it. Id hate to see you order a control board when you need an interface board. Well if the leds are dim then remove top and reseat all ribbon cables 4 each on the interface board and the control board. then turn it back on and see if it works. If not replace interface board then the control board in that order.
Oct 27, 2009 | Whirlpool GEW9250 Electric Dryer
Replace thermal fuse and door latch and still does not run. Power on and beeps once.
Was the thermal fuse blown?
Look at the led indicators on the front of the dryer are any of them lit but very dim? If so it will be a loose connection on the flat cable assemblies 4 each from the interface panel (one with the lights and knob) to the control board located on the top left side of the dryer. If that does not work then Interface board then control board in that order.
If the led indicator appear normal then id look at the control board.
Maytag MED9600S Electric Dryer Logo
37 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
