Question about Goodman GMS90703BXA Heater
Meter shows reverce poliarty when pluged into recptial changed wires around no differance still showes reverced
    Genius:
  • Goodman Master
  • 1,033 Answers
Hello, hot lead must be attached to the brass terminal. The neutral must be attached to the silver terminal.
Posted on Nov 09, 2012
Transmission slips in reverce
Hi Michael, The link below is a short YouTube video showing how to fix your transmission, Also there's videos down the right side of the link that might be worth looking at as well, I hope this helped.... CHEERS..
Fixing Transmission That Slips And Clunks
Apr 28, 2016 | Cars & Trucks
Cant find my reverce 1997 caviler
Check your owners manual for the correct shift pastern...It is a natural H pattern, with 5th gear upper right...reverse should be all the way to the right and lower right to engage...the knob does not always indicate the correct pattern...may have been changed...also be sure it is a 5 speed...most of these Cavaliers were 4 speeds...with reverse being upper right instead of 5th gear upper right...confirm in your owners manual if possible...will show illustration...Hope this helps.
Jun 18, 2015 | 1997 Chevrolet Cavalier
No pix. Red LED blinks 2 times. ( sony KV-24FS-100 TVset. )
this is your over current protection B+, there is a short in the power supply of many of the circuits,fuse,diode,etc, check these carefuly with ohm meter....if fuse is open,only replace it with the same rating,make sure tv is not pluged into outlet...if you need to replace parts,use a desoldering iron,to **** off the solder at pin hole of the part being removed from under side of board also look for burnt spots,then you need wire wick to remove and clean in and the pin hole. reinstall is reverce order,,maker sure you make a good connection,and not over solder it ...keep it clean.hope this helps...........
Feb 22, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The tranny well not engage in drive or reverce
did you change tourqe converter sounds like bad tourqe converter or u dont have enough trany fuild in it
Feb 17, 2010 | 1992 Jeep Cherokee Sport
i hate to say it but it's usually the little things we overlook. back to basics. make sure the trans fluid level is correct and check to see the condition. make sure it doesnt smell burned and that it's a nice clear red color. did you flush the trans cooler lines out? the bad fluid from the old trans may have contaminated the new trans. then make sure the linkage is correctly adjusted. otherwise, it seems like you may have gotten a bad transmission.
Feb 17, 2010 | 1994 Jeep Cherokee
Goodman GMS90703BXA Heater Logo
18 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
