Question about GE (PSS26MSRSS) Side by Side Refrigerator
After changing water filter water dispenser became noisy and then stopped working
Changed to new water filter the fridge made water pipe slapping noise, dispensed water at a trickle. Swithed back to old filter, and it worked. I had another new filter put it in and it did the same thing as the 1st new one. Put the old filter back in and it is not working now either.
  • tomiller381
    tomiller381 Nov 10, 2012
    It turned out that there was Air in the line. Issue is now resolved.
    Thanks for all the solutions.
Joe_Rex
  • 114 Answers
SOURCE: ice and water dispenser not working
ALWAYS MAKE SURE YOUR APPLIANCE IS UN PLUGGED BEFORE TRYING ANY PROCEEDURES !!!!!! MAKE SURE THE WATER SUPPLY VALVE (SOMETIMES 1/4" SADDLE TYPE PEIRCING VALVE) IS NOT CLOGGED WITH SEDIMENT... THEN MAKE SURE THE WATER SOLENOID IS NOT CLOGGED AS WELL ... THE WATER SUPLY SOLENOID HAS A SMALL ORFICE THAT CAN BECOME PARTIALLY CLOGGED OR DOES NOT "SEAT PROPERLY" AND CAN CAUSE INSUFFICIENT WATER SUPPLY AND THUS ERRATIC OPERATION. A LARGE PERCENTAGE OF WATER DISPENSER AND ICE MAKER PROBLEMS ARE DUE TO INADEQUATE WATER SUPPLY. IT IS THE FIRST THING THAT NEEDS TO BE CHECKED !!!
Posted on Apr 27, 2007
SOURCE: Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Posted on Sep 07, 2007
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
  • 21 Answers
SOURCE: GE Profile Performance - No water dispensing or ice making
NOT ENOUGH WATER PRESSURE AT WATERLINE OR WATER VALVE IS BAD AND NEEDS REPLACED
Posted on Jul 15, 2009
cj2176
  • 520 Answers
SOURCE: Water dispenser has stopped working. Ice maker
There are two solenoid valves in the rear of the refrigerator. One that controls water for ice and one that controls water for door dispenser. If the water is not coming through when the button is pushed then have the proper solenoid valve replaced and enjoy. Hope this helps. good luck.
Posted on Jul 18, 2009
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Water dispenser beep-beep
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
Mar 03, 2017 | Hotpoint HSS25GFP Side by Side...
Water not dispensing from side by side fridge
check the primary water valve ,does it make a noise when you push the dispenser ?
Mar 29, 2010 | Maytag MTF2156GEW Top Freezer Refrigerator
Water dispenser is not working
check your water filter (change it) or a water valve in the back of the fridge. make sure it has power on it when the water lever is pushed. if there is power there then most likely its the valve.
Oct 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
I have a rs21dcns fridge freezer. i'm having trouble getting water from the water dispenser and also having trouble setting the temperature control for my fridge.
The water stops flowing from the dispenser when the external water filter needs changing, stick a new filter and it should start working again, it sometimes takes a few minutes to clear the air after the filter change.
Sep 07, 2008 | Samsung Refrigerators
WATER DISPENSER,
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
241 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
