Question about Speed Queen AWN542 Washer
Speed queen AWN552 completed one load without a problem but machine won't start for 2nd load.
    Top Expert:
  • Speed Queen Master
  • 9,472 Answers
Does it fill with water? When you try to start a load, does the timer run?
Posted on Nov 09, 2012
SOURCE: Kelvinator or (Speed Queen Top Load washing machine)
I have a Speed Queen AWM373W top loader with the same problem. We recently had the kit and belt replaced because it was leaking water. That is fixed now but it takes forever. The other night I tutned the drum by hand and it worked fine. Did not had the same problem since but I am watching it.
Posted on Jul 07, 2008
  • 177 Answers
SOURCE: Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Posted on Jul 29, 2008
  • 142 Answers
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
Posted on Sep 14, 2009
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Posted on Jan 13, 2010
My washing machine dont spin or drain water can you please tell me what to do and where about are the filter in then machine/
Either your drain pump is bad or something is stuck in it. It won't spin until it drains so fix the drain pump, and it will spin. You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Jan 13, 2012 | Speed Queen AWS52NW Top Load Washer
Do I put silicon grease on Speed Queen brake pads
Yes. In fact, the complete brake assembly replacement kit is supplied with some high-temperature silicon grease for exactly this purpose. I hope this helps somebody more than the other two posters, who are complete nobs.
Aug 03, 2011 | Speed Queen AWS52NW Top Load Washer
Draining water from inside through center.
The tub seal kit is $85 USD, You will also need a drive bell kit$23 USD, you should replace the upper bearing $?, for a complete rebuilt I would also replace the brake pads all three, and the belt, maybe the pump if it doesnt come off easily. Plus what you break taking it apart, so we are looking @ least $150.
Yes you can do it yourself, you dont need the tub wrench if you can borrow a deep socket, its the drive bell seal tool you really need.
Please let me know if you have additional questions. the serial number will tell you the age first two digits are year next two are month, starts with and R, built in Ripon WI.
May 24, 2008 | Speed Queen AWS52NW Top Load Washer
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Apr 15, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWN542 Washer Logo
93 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
