Question about Goodman GMS90703BXA Heater
Condensation running down old vent pipe running to roof.
Vent pipe from old furnace was left in and the new PVC pipe has been run up through it . We are getting condensation running down the old metal vent pipe and can't seem to stop it.
  • dwkcool May 11, 2010
    sound like the pvc was not ran out far enough and making condensation in the old metal pipe
  • 1,420 Answers
This is a condensing furnace and is ment to condense. You will need to pipe away the condensate using a hose and maybe a condensation pump. It is unclear where the combustion air pipe is going? Are you using room air? or do you have a second pipe going up the old vent as well?
Posted on Jan 06, 2009
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
My high efficiency furnace has water (possibly condensation) running down the air intake pvc pipe into the furnace and all over the burner, gas valve, and wiring.
First, check the drainline from the furnace. You have a 90% gas fired furnace. Where 80% furnace has 1 heat exchanger, yours has 2 heat exchangers. And the second heat exchanger will cool the exhaust enough, that it ends up below the dew point, and your furnace outlet/exhaust will condensate. This drain is probably stopped up. Now, I've installed and service many of these systems and I've only seen the piping at the roof you described once. And that was when the roofers replaced the roof, damaged the furnace flue pipe, and tried to repair it themselves. Normally, and this may not apply to yours, we tie in the exhaust/supply lines about 2-3 ft. above the furnace. Then 1 pipe goes through the roof. Thus 1 pipe is a kit that has an inner liner & outer pipe(2 pipes in 1). Now I'm not sure if this is a problem or normal for your system, but it may be worth looking into. You should be able to find it in the installation manual, or call a local parts house that sells your brand, or as your tech. And if it's just your drain, forget all about the piping I mentioned. Hope this helps!
Mar 08, 2017 | Goodman Heating & Cooling
I have a American Standard furnace Freedom 80 Mod# AUD080C936H3 and am looking for a manal or can you tell me how the exauhst is done. Can I use PVC
Hello, The only time pvc is allowed is if the Furnace is 90% or greater in effiecency, the combustion gases are cooler due to the fact that two heat exvhangers are used. One pipe will be you air intake and the other the exhaust and they can be routed through the roof or sidewall. If the Furnace is 80% then you must use double wall vent pipe and have it connected to either a liner in a chimney or routed through a roof but pvc can not be used.
Aug 28, 2011 | American Standard Heating & Cooling
We have a Goodman GSK9 gas furnace. There is a weep hole on the PVC outside of the house, that in the winter develops a vry large icicle against the house and has damaged our wood siding. When we plugged...
Hello Jmranes,
It sound to me like your getting alot of condensation on your exhuast pipe and a weep hole was drilled to "BAND AID" the issue. These is not how 90% plus furnaces are installed. If you are referring to the outside intake and exhaust PVC piping, then there shouldn't be any weep holes. When the furnace is properly installed, the furnace comes with a condensate kit (refer to owners manual) that is mounted on the side of the furnace and all the condensation that collects overflows and should be piped directly into a floor drain. As for the intake and Exhaust for side discharge application, the Exhaust PVC pipe should come out through the side of house and immediate goose neck up (90 degree) with a straight piece of PVC pipe about 2' to 3' or so in length, then a final 90 degree PVC fitting on that so the exhaust blows out. As for the intake, that also comes out the side of the house about 2" to 3" inches parallel to the Exhaust but should only be a 90 degree PVC fitting facing down. The idea here is making sure the furnace doesn't suck in exhaust air. Also, making sure proper size pipe was used. Both outside pipes should be open to atmosphere. I hope this helps.
Nov 12, 2017 | Goodman Heating & Cooling
How many BYU is a Lennox G40UH (x) series furnace? And can it be vented with PVC? Thanks alot!
The Btu rating for this furnace is 40,000. Since the furnace has a 3 /34" metal flue collar on the top of the unit, you can not use PVC pipe to vent it. Only 90+ efficient gas furnaces can use PVC pipe for venting and the also come equipped with a condensation pump, which yours doesn't.
For more information on your furnace and how it's to be safely installed and vented, here is a link to the installation manual http://www.greenwoodheating.com/products/manuals/gasfurnaces/G40UH.pdf that you can download and print.
Hope this helped answer your questions?
Mar 18, 2011 | Heating & Cooling
Can I vent my ultra v tech 80 propane gas furnance with pvc so I can do away with chimney
Generally, the furnace must be at least 90+ efficiency to be able to use PVC pipe. In addition, high efficiency gas furnaces require a condensation pump, to pump excess moisture out of the furnace. If yours has always been venting up a vent pipe, then NO, you can't use PVC pipe.
Hope this helps you.
Mar 14, 2011 | Heating & Cooling
Dont have a book to tell me how to install heat exhaust pvc or tin
most furnaces require 4 inch vent pipe to be installed ... you can use pvc as long as it is rated for the temperature... there should be an obvious hole in the furnace where the enducer draft motor pushes the exhaust... if this is a upflow unit in the closet you will need to connect to the bell housing of the exhaust and start running your pipe up and out side .you will need double wall pipe rated for heat and or rated pvc if installing pvc... once outside make sure if on rood you have a roof jack for pipe to go through and a collar around pipe to keep water from running down and then a cap on pipe ....if it is a horizontal unit done the same way except your already in attic and don't have a as far to go it can run vertical and horizontal try to minimize your 90 degree turns and is best to keep it angled to prevent moisture from buiding up in pipe...
Jan 25, 2011 | Goodman Heating & Cooling
Is the vent suppose to be pvc 2" or metal 2 wall thru roof on fasco blower
This is an old one, I know they make 2" pvc, but I have never seen 2" Galv. Sheetmetal. I'm
guessing you have a High Eff. Furnace, therefore you would use pvc and be able to go
out the roof or out the sidewall
Sep 27, 2009 | Goodman Furnace Draft Inducer Blower ...
Heat not coming on carrier gas pack code 31
code 31 indicates pressure switch did not close or reopened during the heat cycle....1st thing to check is the inducer motor,,this is a small motor that turns a small blower wheel that draws the exhaust gases through the furnace and blows them into the vent pipe....1st locate the inducer assembly,,most easily identified by the small plastic fan blade that cools the inducer motor as it runs..1st turn off tstat and turn off furnace power switch..then turn on furnace switch,then set tstat to heat,set the temp above room temp by 5 degrees...remove the furnace front cover,locate the inducer motor,,if it isnt turning,but is warm or hot after a minute or so,likely the inducer motor is bad..if it isnt turning and isnt warm after 1 minute,then likely the main control board is bad,,not turning the inducer motor when it should,,,,,if the inducer motor is running,,then the pressure switch isnt closing,, could be a bad pressure switch but more likely there is a problem with the venting...some possible problems that would cause the pressure switch not to close in an 80% eff furnace [metal vent pipe] are: [1] a blockage in the vent pipe,base of chimney,dead bird at the furnace where vent connects to furnace or down inside the inducer assy,accessed by removing vent pipe from furnace....if all clear the chimney could be blocked up inside,,is the draft good when vent is removed from base of chimney?..if furnace is a 90%+ type [pvc plastic vent pipe],,then check the intake pipe at the furnace by removing it where it attaches to top of furnace..is the intake clogged with anything?..then check the intake and exhaust pipes outside for blockages,,including ice/frost/snow at the exhaust pipe outlet..
Jan 26, 2009 | Goodman GMS90703BXA Heater
My furnace is leaking water when the heat is running
You probably have a 90+% efficient furnace. They produce condensation. Does it have PVC vent pipes? If so there is a drain tube for condensation.
Jan 23, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
294 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
