Question about Sova DSV32P112 32 in. LCD Television
No power getting to TV.
When I plug the power cord into the TV the power goes off. The blue light on the pwer adaptor just fades out and the TV light does not come on.
I have a 32'' Sova LCD tv with the same problem. The problem maybe your power supply. In my case, it was the power supply (no.# YHi 090-02180-13) it had no voltage out put, no blue light and no working fan. Remove the power supply and take it to your local repair center and check it for voltage out put. I found it difficult to locate the same power supply after the decision not to repair mine. There is an alternative I found on ebay, it doesn't look the same, but all the spec checks out. I had this power supply for two days and my tv work great so far so good.
Posted on Jan 12, 2009
  • themandjd70 Sep 14, 2011
    I had the same problem.I just bought a new power supply,but my son failed to tell me that he cracked the LCD screen..so now I have a brand new plug and have no use for it..if you want it,just give me what I paid for it.which was $109 plus tax.like $125..u can contact me via. Email ..douglasdedes70@yahoo.com.. My name is Doug
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
VP422 plasma will not hold power If i plug it in the yellow Vizio lights up then fades out
The set is going to have to be taken apart and looked at: a guess would be to start with the main power/power supply board.
Mar 15, 2012 | Vizio VP422 42 in. Plasma TV
The sound and picture goes out on my LG lcd tv. Power light stays on
if you are not a tech then take your tv to a repair man.there is a problem in your tv power supply...the pwer supply is attached to where the power cord leads to the wall outlet.good luck.kindly dont make repairs yourself.
Sep 23, 2011 | LG Televison & Video
I plug my igo charger into the wall and the it glows blue but as soon as I plug the other end into my computer the blue light fades out and my laptop stays dead
Fading or flashing power indicator on the adaptior points (usually) to a fault in either the adaptor itself (internal short) or a fault on the charging / power circuit on the laptop. The reason the light is dying is the laptop is not drawing power, ergo the electricity has no circuit to make.
Before condemming either:
1.) Check the laptop on an adaptor of the same or higher wattage (and voltage)
2.) With a multimeter, set to 20V DC and probe the jack inner and outer contacts (red to inner contact, black to the side of the jack (earth), see if you get a reading
3.) Check the security of the DC port on the laptop, it should not be sloppy or loose, if it is, you will need to get a new DC port soldered or plugged in the board (cheap fix if you are any good with a soldering iron)
After that, the issue lies with the laptop itself, will need a shop to sort out
Jan 06, 2011 | Computers & Internet
Stand by light no on ,tv will no turn on .pwer to tv checked
unplug tv for 1 min. plug power cord into known working outlet. if same, tv needs service. check local servicers from yellow pages
Dec 24, 2010 | Televison & Video
No pwer to the protron
The powerboard is damaged, just replace it and that will solve the trouble.
Jul 01, 2009 | Protron PLTV-32 Television
No Power
there is a chance of battery failure
Feb 14, 2009 | Dell Inspiron 600M Notebook
Can you help me find a pwer cord for my 32''flat screen (Proton)
Unless this set is really oddball, it probably has the same type power cord connector used on computers and so many other electronic appliances. If this is the case, you can use a standard computer power cord as a replacement. The computer cord is a three-wire plug with a ground pin and the TV probably only had a two-prong plug, but the cord will still fit. Your electric outlet should be the three-prong type (if it's not, get it replaced!) so the plug will fit.
If the connector in the set is really different, you can check online by doing a Google search for replacement parts for you TV.
Nov 21, 2008 | Proton MM2701VT 27" TV
No Power to my TV
if you still have a problem (and the tv!) email me at gmail.com
Nov 27, 2006 | Protron PLTV-32 Television
Sova DSV32P112 32 in. LCD Television Logo
306 people viewed this question
Top Sova Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
loony2ns
Level 1 Expert
Are you a Sova Televison and Video Expert? Answer questions, earn points and help others
