Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
C950528160 snow blower. pull start does not engage
Starter pull cord is attached and does recoil. When pulled it does not turn over engine
3 Suggested Answers
  • 3 Answers
SOURCE: recoil starter will not engage engine when stater
The tooth/notches in the housing are worn out or broken,if the pull cord returns to the original position than the return spring is still good and you will only need to worry about replacing the gear/housing that attaches to the crankshaft .Good luck on the repair job ..BOB
Posted on May 03, 2009
  • 141 Answers
SOURCE: when i pull the starter cord it pulls back really hard
pull off the spark plug and spray wd40 wait 15 min to 30 min and then pull without spark plug in then put the spark plug back in and then try it
Posted on Apr 15, 2010
My starter cord will only pull out about 6 inches and then it's stuck...
If the recoil will only pull out a little and it appears to be good when you removed it, then pull the plug on the engine and pull the recoil rope 3 times all the way. Important - watch the plug hole each time to see if black debris blows out. Then squirt 1 time WD40 in the cylinder head thru the plug hole. Clean, gap the plug or replace if required. LM19 I think, plug is marked. RE-install plug, attach laminator connector. Pull recoil rope again, should be free if engine isn't seized. Make sure oil has been changed this year, 30W, and is full. Check air filter also while you are doing this basic maintenance.
Jun 19, 2016 | Honda HRX217VKA Lawnmower
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
How to fit a recoile spring to my husqvarna stimer
you can pull the rope and it recoils just fine but it's not gripping the engine's crankshaft then most likely it's one of your recoil's starter pawls, the part you'll want to look into is called that, a pawl, and it's either the pawl itself or the spring that attaches to it
Aug 18, 2014 | Garden
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Engine doesn't turn over pull cord stuck
remove the starter assembly and see if it is the recoil or engine. if by removing the recoil it recoils the cord then it is most likely a seized engine but pull the rope a few times with the assembly in your hand to check it then try turning the flywheel by hand and see what happens
Feb 09, 2013 | Garden
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
When pulling cord to start mower there was a click sound and the cord would not rewind
Remove top cover to your engine with all other attachments. Be careful because loosening this part will most likely recoil the cord. The recoil is in the top of the cover. Turn cover over and put some oil on all the mechanical parts at center of unit. Pull the cord till your satisfied it has been lubricated.
Replace top cover along with all attachments, and you should be ready to mow. GOOD LUCK.
Jul 25, 2011 | Garden
How to change the pull starter cord.
drill out rivets then re-rivet or use self tapping screws
Oct 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Starter cord only pulls 1 foot
Most push mowers have 3 bolts on the side of recoil shroud. One in front, (where plug is) and two on side.
Apr 12, 2009 | Garden
Broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Sep 09, 2008 | Garden
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
56 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
