Question about Relic Wet ZR15409 Watch
Is there a battery
Relic zr15372
What is the battery size relic zr15610?
Take your Relic watch to a jeweler who, for a reasonable sum, will replace the battery.
Dec 03, 2016 | Relic Watches
Need battery number for relic women's watch model zr33940 battery was lost
take it to a store that sells watches they might be able tomatch a watch to it .
Apr 08, 2015 | Relic Watches
Where to find batteries for relic watches?
Relic watches use common internal movements and common batteries. They can be found at most drugstores, radioshack and jewelry stores. The trick is getting the back off without damage. Best bet, jewelry store.
May 26, 2014 | Relic Wet ZR11672 Wrist Watch for Women
What is battery number for relic watch zr11811
Just replaced the battery in my colleague's Relic ZR11811. The battery is a 371. Equivalents include AG6 and SR920.
Apr 09, 2013 | Relic Watches
What kind of batery need for relic zr 15490? i don't know because i lose my old batery.
mcdevito75 Here, Your in a spot, Looseing the old battery to your Mens Relic watch, you can look for a small watch repair shop in your area, they may have an idea of the battery number, but will most likely tell you they need the watch to know for sure. You can also try battery 364 or 371 but even I can"t be certain. You can also try online at Contact Relic Watches.com Reic should have a website. You may be left with only 1 choice, have the watch repair shop replace this battery for you, you"d have to buy and try a couple of different batteries and each battery in the store runs about $5.00 each, at the watch shop let the Jeweler figure out the battery number for your watch for 1 price. I think this is your cheapest and best option.
Feb 11, 2011 | Relic Dial ZR15528 Watch for Men
Does not run. does this watch have a battery in it?
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
http://relicbrand.com/
Nov 13, 2009 | Relic Multifunction Watch
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Relic Watch Band Removal
If there are holes where the band connects to the watch and you are unable to push the spring bar out. There may be a bar connecting the band to the watch. Those are harder to push out.You might have to use a tool & hammer it with a gavel. Hope this helps
Mar 04, 2008 | Watches
Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Feb 14, 2008 | Relic 0504648FA
Relic Wet ZR15409 Watch Logo
37 people viewed this question
Top Relic Watches Experts
Andrew Taylor
Andrew Taylor
richie46
Are you a Relic Watch Expert? Answer questions, earn points and help others
