Question about Toshiba Satellite M105-S3041Notebook
Worked fine yesterday, today zilch !!
This is my daughter's machine; she is in college and the machine is about 2 1/2 yrs old. Yesterday it was a good little Toshiba Satellite M105-S3041 PC doing its thing either running off the battery or AC.
This morning nothing and I mean nothing. No lights anywhere, no humming, no fan, nothing with either power supply (and yes, the ac outlet is proven as live, and yes, the battery was taken out and reset, and yes the machine is still dead when powered ac without the battery in).
After its last known usage, the machine was properly shut down and left plugged in to the wall overnight.
on/off switch? power pack shot? overheated? any other ideas or diagnostics tests?
  • cesartech30 Mar 28, 2009
    using my laptop when battery warns i plug the ac adaptor then the notebook loss power even the stanby light was not lit.. any resetting remedy for this? or my motherboard need to be replace...
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 116 Answers
One computer I fixed had its internal power regulation confused. With the AC adapter plugged in, holding the power switch down for twelve seconds, then pressing it again, switched it back on. This sort of problem can come from a variety of causes, though. There is an internal power distribution chip which could have received a static electric shock or power surge and gotten cooked. The RAM could have gone bad. The socket where the adapter plugs into the computer could have been cracked loose. Check the power switch and then RAM first, and write more if that doesn't fix it.
Posted on Mar 22, 2009
2001 Touch Tronic. Worked fine yesterday. Today, why can't I wind a bobbin?
If you haven't cleaned and oiled your machine recently, you might start there. Consult your owner's manual, use ONLY fresh, good quality sewing machine oil, and apply 1-2 drops of oil each spot specified in the manual.
If the machine bobbin winder is still not working, does it still sew? If so, you probably have two choices:
1) Take it in for service
2) Buy a standalone bobbin winder (~$30) from JoAnn's, Hancocks, or Amazon.com
If the machine does not sew, take it for service.
Dec 28, 2015 | Singer Sewing Machines
Amana washer error code
This is an open door error. check the latch and switch on the machine.
Feb 05, 2014 | Washing Machines
Epic 450mx console lights up but nothing works not even the fan, worked fine yesterday
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.
2) See inside for any fuse blown adn replace, or c.breaker reset
3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagram
God bless you
May 08, 2012 | Epic 450 Mx Treadmill
Summit ignitor Worked fine yesterday, today no ignitor.
Check your ignitor wires for broken or disconnected connections.
May 14, 2010 | Weber Genesis Gold B Grill
Worked fine yesterday - will not turn on today - kitchen
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Feb 07, 2010 | IBM ThinkPad T40 2373 Notebook
The microphone worked fine yesterday, but today it doesn't work. Help, please!
Mostly the cause should be because of the hardware problem. Try using another device and ensure
Dec 12, 2009 | Dell Latitude D600 Notebook
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Poor screen quality
re install your dell video card driver
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
Toshiba Satellite M105-S3041Notebook Logo
181 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
