Question about HP xw4400 Workstation PC Desktop
Cannot install new hard drive on HP xw4400 Workstation
Cannot install new hard drive on HP xw4400 Workstation get this error "setup did not find any hard discs installed" (yet BIOS sees HD,and CD) must be some hardware configuration what has to be changed in BIOS to install a new hard drive on HP xw4400 Workstation?
    Habit-Forming:
    Scholar:
  • 111 Answers
Check the to see if its in master or slave configuration.Also a great boot tool is Hiren's BootCD and here the link below.If you a tech to call you for a step by step help go to our website and the that link is below as well and take care.
http://www.hirensbootcd.org/download/
http://www.ezsystemrepairs.com/
Posted on Nov 09, 2012
Cytherian
  • 109 Answers
SOURCE: How to install new hard drive
Hi Mark,
External drives have come a long way and run almost as fast as many internal drives. If your need for extra hard drive space is pretty much driven by the Microsoft Flight Simulator game, you could get by with using an external drive. A few things, though: Make sure your system is supporting USB 2.0 (it should be) and that the drive runs at least 5400rpm. External HDD's run off standard 120v AC power.
Otherwise, if you want to get an internal drive, you can certainly get another ATA-133 drive. But SATA is faster and your computer may support it. The D530 CMT (convertible mini-tower) definitely does. But there is also the D530 SFF (small form factor), and D530 USD (ultra slim desktop)--not sure if those are rigged for SATA support.
As for maximum hard disk size supported, that's up to the operating system (e.g. Windows XP vs. Vista). You likely won't need any bios updates because of a new hard drive installation. However, its not a bad idea to review the BIOS update release notes to see what they're addressing.
Posted on Dec 30, 2008
SOURCE: maximum IDE HD size for HP d530 SFF (Bios 786B2 v1.11 07/10/2003)
no its not a hdd problem, its a mobo problem max u can use is 160 with that pc, what u can try is a bios upgrade and hopefull it helps
go here for the updates:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
choose ur os like xp or vista
than download the updates
Posted on Jan 02, 2009
  • 3940 Answers
SOURCE: Problem with recognizing 2nd hard drive in Compaq EVO D510
you need to initialize the newly added drive in disk management, then format the drive once disk management assigns a drive letter.
CONTROL PANEL, ADMIINSTRATIVE TOOLS, COMPUTER MANAGEMENT, DISK MANAGEMENT
There you should be able to see the 2nd drive, Right click and INITALISE it, once it is initialized, it will be assigned a drive letter and you can format the drive
Posted on Feb 05, 2009
SOURCE: HP Workstation xw8200
Server 2008 is not detecting your drives, because it does not have drives for what ever hard drive controller you are using. You will need to determine which controller your drives are attached to and load the appropriate driver during setup. I believe this system has built in SCSI and SATA controller and often shipped with add - in storage cards. Our came with a promise sata raid controller.
Posted on Jul 22, 2009
ic0729
  • 212 Answers
SOURCE: install hard drive in hp a1310n
You need to do a number of things:
1) You need to carefully remove the door and the whole front face of the desktop (the front face opens like a door it swings open from left to right)
2) Once you have the front pannel open take a philips screwdriver and unscrew the memory card readers that is show in front of the deskop (there is one screw holding this card reader in place probably on the upper right hand corner.
3) Carefully remove the card reader by jiggiling it lightly till the unit comes off.
4) After you remove the card reader, you will immediatly see the hard drive directly behind the reader that you just removed.
5) Now look inside the desktop (because you removed the right hand side door: the big one that alows you to see inside the pc) and remove all cables from this hard drive before you read #6 below
6) Inside the desktop, Locate the hard drive, put your hand on the back of it and lift on the green plastic part along side the hard drive where you can see the harddrive screw which is on a metal track stopped by a green plastic stopper.
7) Lift the green plastic stopper and push the back of the hard drive to the front of the desktop.
8) Unscrew all screws from old hard drive and rescrew them on the new one in the exact same spots at the old hard drive.
9)Once you finish screwing on the screws, slide the new hard drive back from where the old one was
10) reconnect all data cables and power supply cable.
11) follow steps 7 thru 1 to put unit back together again. Go thru steps 7 thru one backwards
I hope this helps
Posted on Mar 18, 2010
HP xw4400 workstation wont boot/start if RAM are inserted.
If you are increasing the RAM from 1Gb to 2Gb then the RAM maybe incompatible. Try using a RAM module as the original make and speed.
Try installing one RAM module at a time to see if one of the RAM modules is faulty.
Removing the RAM will give a POST error code of no RAM or faulty RAM.
Feb 25, 2013 | HP xw4400 Workstation - 1 x Intel Core 2...
HP xw 4400 will not recognize my hard drive when trying to install OS Windows XP Prof.
Windows XP had a hard time recognizing hard drives larger than 127 GB. The best solution is to install Windows XP with service pack 2 or 3 already slipstreamed. Otherwise, you are going to have to partition your hard drive with at least 1 partition of 127 GB or smaller.
Dec 08, 2012 | HP xw4400 Workstation PC Desktop
Windows 7 not installing in Hp XW4100 workstation
Sounds like you need to format the hard drive then try a new install
Jun 21, 2012 | HP Workstation Xw4100 PC Desktop
Is the video card PCIe compatible? I just assumed that by its age that it would be a standard PCI. I was wrong. Allan
System features of HP xw4400 Workstation on official HP web site state:
Expansion Slot
6 slots: 1 PCI Express (x16) Graphics slot, 1 PCI Express (x16 mechanically, x4 electrically), 1 PCI Express (x1) and 3 full-length legacy PCI slots
So it should work fine with modern PCIe graphic cards
May 20, 2011 | HP xw4400 Workstation - 1 x Intel Core 2...
My name is Courtney and I own an HP xw4400 workstation. I need to recover it, but I cannot enter into safe mode. Every option that I push at start up is taking me to the same menu, the MBA Configuration...
It sounds like your hard drive has completely failed on you.
Without a functioning hard drive, the computer cannot load the operating system at all -- even into safe mode.
You will most likely need to take the system in to a service facility to have the hard drive situation diagnosed and your operating system restored.
Dec 20, 2010 | HP xw4400 Workstation PC Desktop
1881-microcode update error missing invalid processor microcode
A new BIOS is needed.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=ca&prodNameId=3211221&prodTypeId=12454&prodSeriesId=3211220&swLang=13&taskId=135&swEnvOID=1093#120
Download (as in Save, not Run) both and run the utility afterwards.
Mar 11, 2010 | HP xw4400 Workstation 2.66GHz Core 2 DUO...
I have a static noise coming from my speakers when listening to music through my computer. I put in a new sound card same problem. What can I do to fix this?
do you have you cell phone closeby or any other wireless devices? go to setup and reduce the volum on some of the devices that may help too especially the mic
Nov 08, 2009 | HP xw4400 Workstation (RB351UT#ABA) PC...
Apr 20, 2009 | HP xw8200 PC Desktop
HP xw4400 Workstation PC Desktop Logo
312 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
