I cannot get either Ch7 or Ch72 on my new Conia CE3201HDVDR. All the other channels work fine, since I bought an indoor antenna. Have tried both auto-tune and manual tune.
All the other channels work fine, since I bought an indoor antenna. Have tried both auto-tune and manual tune. Don't want to tamper with Frequency etc., as I'm not qualified to do that and don't understand it anyway. Your advice would be appreciated.
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
SOURCE: Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now livi
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
Posted on Jul 22, 2009
emissionwiz
  • 75822 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Posted on Jul 28, 2009
  • 668 Answers
SOURCE: Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Posted on Jan 05, 2010
Testimonial: "Thx for your help, I wondered if tou thought If I could put an outdoor antenna on our balcony, seeing as I have no roof access and another apt. above "
SOURCE: Channel selector does not work; can not auto tune
Sorry not be able to solve the problem. I have exactly the same problem. So it is not related to anything you've done. Something faulty in the TV. It happened after 1.5 years in my case. Any tech support link appreciated
Posted on Jan 12, 2010
What antenna works on Toshiba 20VL43U? I purchased Mediasonic Homeworx HW110AN Super Thin Indoor HDTV Antenna - 25 Miles Range.
I recently went through a whole song & dance about HDTV antennas for my RV. I bought two different directional high-gain antennas, only to find that they wouldn't even receive signals at my home! When I'd reorient the antenna and initiate another channel search, I would sometimes get ONE or TWO channels... then I'd lose them when I'd try to reorient the antenna.
What I figured out is that DIRECTIONAL HDTV ANTENNAS ARE, ESSENTIALLY, WORTHLESS. There is really no way of knowing precisely which direction the broadcast towers are and, even if you knew, they will not all usually be clustered in one small area... they may be scattered here & there around your area.
What I eventually did is bought an OMNIDIRECTIONAL HIGH GAIN ANTENNA, which was no more expensive than the DIRECTIONAL antennas I tried. Did a channel search, and got almost all of the channels in my area!
Any omnidirectional HDTV antenna will work with your television, but I'd recommend buying the one with the highest GAIN (expressed in "dB" or "dBi" with the highest number being best). Try to find a POWERED antenna with an internal SIGNAL AMPLIFIER.
Also, if you live far away from broadcast towers as I do, you may wish to consider adding an additional SIGNAL AMPLIFIER as well.
May 21, 2015 | Toshiba Televison & Video
I purchase a Sony Bravia KDL-32xbr6 in 11/08. I want to get rid of satellite due to bills increasing. I cannot figure out if I have an HDTV tuner inside the tv or not. Anyone know? DO I need to...
Your LCD has a digital tuner and should receive free channels using an indoor antenna but it would receive more channels if you have an outside antenna, depending on where you're.
If you are closer to a transmission tower the indoor antenna should work fine.
Let me know if you need further assistance.
Oct 02, 2010 | Sony Televison & Video
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
I have tried two different antennas and the screen says that the signal is weak I bought the TV today
If you're using an indoor antenna (rabbit ears), you'll find that there's little difference between them. Yes, you'll see all the fancy knobs, but mostly all they do is delay the signal from making it to your antenna jack, hopefully enough to reduce ghosting on analog channels...or a resistor circuit that reduces the signal strength. Receiving a good signal with an indoor antenna can be difficult...there can be obstacles between your tv and the broadcasting station, you could be too far away...it's hard to tell. Before you use an outdoor antenna (consider a good RV antenna if you need to use it indoors), try an antenna amplifier. It'll have to handle both VHF (at one time channels 2-13) and UHF (channels 14-69 analog). If it's an "antenna amplifier," it will be sufficient. If it's a cable amp, it would be a hit-or miss. The amp may be able to boost your signal with the indoor antenna you have now. Alternately, you can buy an indoor antenna with the amp built in. Hope this helps.
Jan 20, 2010 | Sansui DTV1300 TV
We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Dec 07, 2009 | LG LA125HV Split System Air Conditioner
Basic broadcast channel plan vs. indoor digital antenna
HD tv is picky about the signal. You either get a signal or you don't get a signal (no static or snow). It really depends on your location as to where you live. There are ways that you can find out how close you are to a transmitter by checking on Wikipedia for each channel in your market. It will give you precise position as to where it is. It will also tell you if they will broadcast in 1080i or 720i. Check the antenna specs to see what the range is on the rca.com website.
Jan 28, 2009 | Televison & Video
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
