Question about Roper Dryers
Roper dryer turns off after 5 min. disconected vent line,will run longer but still shuts off.
    Top Expert:
  • Roper Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 11, 2012
Illeagle
  • 525 Answers
SOURCE: Whirlpool LGC8858EQ0 Natural Gas Dryer Problem:
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0088_8_1.asp
If your dryer doesn't heat, check these:
Temperature Switch, make sure a positive heat selection has been made. Then check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 04, 2008
  • 91 Answers
SOURCE: dryer shuts off after 5 or 10 minutes
repl/ thermsitor if avaiable if not repl/ hi limit thermostat on top of ignitor
Posted on Jan 04, 2009
kachbibi1
  • 979 Answers
SOURCE: roper dryer no heating properly
Have you checked the lint trap and made sure the entire exhaust is clean? You may have a bad control switch that won't allow it to ignite on medium. The bigger problem is the short time cycle. Something is telling it to shut itself off for safety reasons.
Posted on Feb 11, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Dryer runs for about 5 minutes then shuts off. It gets hot and drum rotates but it keeps shutting off. Then it takes about a half hour before it will start again.
It sounds like you're not getting good airflow and thus tripping the thermistor. Make sure all the vents are clear and the lint trap is clean.
Mar 07, 2011 | Roper REX5635E Dryer
Roper dryer runs for about 5-10 min. then shuts off. After 10-15 min I can restart, but same thing happens. What up?
disconnect vent tube and run dryer, if it finishes the cycle then there is a restriction in the vent tube
Dec 26, 2010 | Whirlpool Dryers
Dryer cuts out after about 3-5 min of use, removed vent pipe from dryer and still same results.
The only thing that would make it quit would be the motor overload. If it was the fuse the dryer would die and stay dead till you replaced it. heater limits go out she gonna still run. It has to be the motor overload. Reach inside and turn the drum by hand. If it turns easy then your motor is probably overheating. Sometimes you can get a little more life outta that motor. HERE IS HOW
Dec 20, 2010 | Roper REX4634KQ Electric Dryer
Dryer run then get hot after about 10 min. it stops want start till about 2 hours later
try runing the dryer with out the vent hose.if it drys good than you have a problem with your vent line.
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
Our GE Profile dryer keeps shutting off, regardless of setting, after it has run for 4 or 5 min. Could it be overheating or maybe the vent to the outside is clogged?
it certainly sounds to me like a blocked vent issue somewhere along the line and in order to prevent a fire the safety thermostat shuts the heater off. are you saying the dryer stops altogether, not just the heat?
Oct 24, 2009 | GE Dryers
Dryer overheats and shuts off- vents have been cleaned and button on back has not reset
Common problem.
You probably need to clean
your dryer vent. Dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
I'm pretty sure that's it. Good luck.
Apr 15, 2009 | Asko T731 Electric Dryer
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Dryer keeps blowing the fuse in the fuse bow
check your venting going to the outside it sounds like it is clogged run a load with out the vent connected to the back and see if it works ok if so you need to brush clean the vent to the outside
Jan 21, 2008 | Kenmore 63932 Electric Dryer
Dryers Logo
42 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
