Question about Jenn-Air Microwave Ovens
How do i remove a built-in jenn-air microwave?
I need to replace fuse in jenn-air microwave
  • Jenn-Air Master
  • 9,098 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If not, try here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the fuse is good, it may be the magnetron thermal cutout (TCO or thermostat) or the oven cavity thermal cutout (TCO or thermostat).
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
Jenn-Air M170 Microwave Oven "dimensions
http://kitchen.manualsonline.com/manuals/mfg/jennair/m170.html
Toll free 800 number and email for support.
https://www.justanswer.com/appliance/6r6z4-dimensions-jenn-air-m170-built-in-microwave.html
Link above states:
What are the dimensions of the Jenn-Air M170 built-in Microwave...
What are the dimensions of the Jenn-Air M170 built-in Microwave Oven (built 1998) that I need to specify for a replacement unit? Externally, I see the frame measuring 26 3/4" W by 17" H, and the unit within the frame measuring 22" W by 13" H.
Share this conversation
Answered in 1 hour by:
6/5/2012
Appliance Technician: Ed Michaels
Ed Michaels : Hi, your machine is long out of production and installation instructions usually come with the machine and are not published. you have a standard size 24" built in machine, and most 24" machines will fit the space. I would click on Jenn Air or call 1-800-JENN-AIR (536-6247) and ask for a replacement recommendation and a copy of old installation instructions for planning with designer or installer. They have access to records if anyone does and an interest in serving you. Alternatively, talk to another seller and discuss installation. they will also want to help. Let me know if I can help further.ed
Mar 08, 2018 | Jenn-Air Microwave Ovens
Jenn-Air jmc2430 built-in does not run.
Hey David... sorry to say
There's a $14 fuse between cooking & your magnetron (could be other things (but in my opinion... magnetrons sound right for your symptoms)
I checked for your magnetron
and got MFR Number 461967847321 - not AVAILABLE.
(there is one $74 on eBay (
very bottom, below)).
I LOOKED at your oven and it is a really nice one...
So I think I'd be hitting all the on-line parts houses
to see if you can locate one...
Jenn Air jmc2430 built in does not run
http://www.appliancepartspros.com/whirlpool-magnetron-461967847321-ap5987313.html
461967847321 NEW MAGNETRON WHIRLPOOL KITCHENAID MICROWAVE NON OEM WITH...
May 15, 2016 | Jenn-Air Microwave Ovens
Jenn air microwave quits working after 11-13 seconds of heating
open circuit switch when power reaches this switch it will shut down as switch is us
Aug 12, 2012 | Jenn-Air JMC8127DD Microwave Oven
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn Air Microwave won't cook
I had the same problem with mine wich is the same built in Jenn Air jmc7000 after using an ohm meter to check some of the switches I discovered the door swith was bad replace it for about 5 dollars and it works as good as new...Good Luck
Jan 04, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
May 01, 2008 | Microwave Ovens
Setting clock on Jenn Air M166 built in microwave
sure..push clock pad twice..set time..push stop/start
Mar 09, 2008 | Microwave Ovens
Jenn-air microwave JMC 7000 ADB has no power
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
222 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
