Need a developer drive wheel for a mfc-8440, its in the back of the machine on the internal right size, its plastic, black in color, has teeth and both my machines have broken ones, the machine jams the paper and will not totally feed it ...need to find the parts only and a picture of the internal parts from the back of the machine so I can choose the correct parts number........what is the cost of this wheel or cog ??
    Champion:
  • 320 Answers
THIS SEEMS LIKE THE FUSER SECYION THAT YOU ARE TALKING ABOUT, IF THIS ISTRUE, YOU CAN NOT BUY THE GEAR YOU WILL HAVE TO REPLACE THE FUSER UNIT BROTHER TECH
Posted on Jan 19, 2009
MACHINE ERROR CODE 6B ON BROTHER MFC-8440 ?
A6 error means the CIS unit is defective and needs to be replaced.
Unfortunately this can sometimes cost more to replace then the machine itself
Thank you
Regards,
Suhail
May 16, 2012 | Brother MFC-8440 All-In-One Laser Printer
WHEN I TURN ON MY MACHINE BROTHER MFC 8440 I SEE ON THE SCREEN ERROR MACHINE 6A I NEED A SOLUTION
Error factor: Heater warming-up timeout error.
(Heater does not reach 60°C within 11 sec.)
Check: • Thermistor ASSY
• Halogen lamp
Jan 08, 2011 | Brother MFC-8440 All-In-One Laser Printer
Machine error 6F on a brother mfc-8440 how can I fix this. I need to print bad
this could be either the thermal fuse on the machine or the power suply. it means that the fuser on the machine is not heating up. this error would need servicing on the machine unfortunatly
Mar 31, 2010 | Brother MFC-8440 All-In-One Laser Printer
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
Machine errore 6e brother 8440 mfc
You have a fault with either the Halogen lamp or the Power Supply PCB, basically the heater in the printer is not heating quick enough.
Mar 21, 2009 | Brother MFC8440 Remanufactured Laser...
Replacing Brother MFC-8440 Fuser
To remove the fuser - remove the tray at the bottom and the back tray (4 screws, 2 either side) lift out the phone line box on the right (looking from the back - 2 screws) and swing it out of the way (careful as cable isn't too long) 2 screws either side of the fuser (long black object at the bottom) unplug the halogen lamp (white plug on left) and small 5 wire plug on right, and lift out fuser unit.
Aug 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
47 people viewed this question
jasbo
jasbo
