Question about Brother LS-2125 Mechanical Sewing Machine
Do you oil bobbing case - Brother LS-2125 Mechanical Sewing Machine
    New Friend:
If you still have your manual, it should tell you all the places you should oil it. Otherwise you can find a manual online at http://www.brothersewingmachines.gur.co.uk/manuals/5408_Brother_LS_2125_Sewing_Machine_Manual_in_English.pdf
It's on page 43 (51 on the PDF)
Hope that's helpful!
Posted on Nov 20, 2012
How to fit my bobbing casing?
Use your hand wheel and turn it. Monitor under the throat plate. The part you see moving will eventually show an opening. Stop there and install your bobbin casing. If it has a little metal piece across you will have to lift it slightly. After it is snug you can install the bobbin.
Mar 20, 2015 | Sewing Machines
Machine is 30+ yrs old and the tensions settings are ALL screwed up so it won't sew even tight stiches...need help setting all (3) tension dials...please help me!
Real Important: The objective is to even the top and bobbin tensions equally.
1. Remove bobbin case. Put bobbin in (rotating counterclockwise).
2. Put thread under the tension plate. Let the bobbin hang from finger and bob up and down lightly.
3. Adjust tension. The bobbin should extend one inch every time it is bobbed.
4. Put one drop of oil on race the bobbin case sets on top of. Replace the bobbin case and bobbin.
5. With the pressure foot up thread the top and give little tugs as you do this. There should be no snags or resistance. Make sure the thread goes in between the tension disc.
6. Now, put pressure foot down. Give a little tug to see if there is a resistance. Set the tension to four is a good start.
7. Try a piece of rag to sew. Set the tension on top to adjust for a perfect stitch.
Mar 04, 2015 | Sewing Machines
Bobbin case for 7462 singer how do u put in the machine
Open Up The Door Below The sewing Foot. Lift Lever And Then Pull Out the Bobbing Case Replace Bobbing And Put Back Together
Feb 02, 2014 | Singer 7462 Mechanical Sewing Machine
What is the hook race
The hook race is the part of the bobbin assembly that revolves when the bobbing case is removed. You would put a small drop of oil directly on the inside of the part that revolves, then return the bobbin to its proper location. Hope this helps. You can also view a great video on youtube that shows you exactly how to take care of it.
http://www.youtube.com/watch?v=hJCRfpO_MVo
Dec 04, 2013 | Bernina Artista 180
Singer confidence 7470 while sewing the bobbing lifts up and makes a clanking noise the faster you sew. Any suggestions to this problem please?
It sounds like the bobbin is stretch. I fix mine taking a little screw driver (the one that comes with the machine) and turn the little bobbin case screw a tad to adjust the size of the bobbin carriage. Does the sound comes from the upper side of the machine or the under (bobbin) side of the machine? Did you oiled it correctly?
Nov 30, 2013 | Singer Sewing Machines
Nesting at startup sewing machine
try using a new needle--make sure it's the right one for the fabric
your sewing
try rethreading the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
check to see the thread has come off the thread take up lever
check with brother customer service about oiling the machine
some you oil and some are self oiling
Nov 08, 2012 | Sewing Machines
Bobbin won't wind on Sears Kenmore model 1756
You need a bit of oil on you bob winder shaft and then work it in turning your bob winder or your bob winder rubber ring could be worn.
Jan 19, 2010 | Sewing Machines
NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Oct 24, 2009 | Singer Featherweight 140Q
Thread keeps knotting up in bobbing casing
Make sure the bobbin is wand correctly. It also need tension. you have a bobbin case be sure it inserted correctly.
Aug 08, 2009 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
