Question about Maytag MDB7100AWB Dishwasher
Maytag mdb7749awm1 dishwasher
Trying to remove lower spray arm to clean filter. Inside of door is spattered with food debris after each wash load.
  • 1214 Answers
SOURCE: Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Posted on Jan 24, 2009
rickzilla
  • 706 Answers
SOURCE: Dishes not getting clean, white film
Hello cljjtm,
You will need to clean the wash arm and unclog the spray holes.. use white vinegar to break down the soap deposit and a sharp metal tool such as an awl to free these holes up from any build up.. white vinegar may be applied while unclogging the openings..
Then, once the spray arm holes are freed of deposits..Start with an empty dishwasher.. and then start a wash on the hottest available setting and then after a few minutes of it cycling.. pause it and add a cup or two of white vinegar to the wash ( the white vinegar should break down any soap residue and allow it to be rinsed away)..once complete.. use about 1/3 less detergent than you have been. See if that gets your DW back in working order.. Hope that helps..
Regards,
Rick
Posted on Feb 16, 2009
  • 677 Answers
SOURCE: Maytag dishwasher filter keeps clogging
There is a product made to filter the water going into your dishwasher only to soften the water and remove the calcium before it enters your dishwasher. your dishes will be spotless and it will not get clogged again. you can get it at www.dishwasherfilter.com. it goes right under the sink and is very affordable. you will love this product and it will solve your problems.
Posted on May 07, 2009
Maytag317
  • 1136 Answers
SOURCE: clogged filter
Hi, The mesh does not open. You will need to GENTLY clean each section with running water. Are you using powder or liquid soap?
The most common thing that plugs them is food particles. This unit is best served by pre-rinsing the dishes. The mess gets plugged to easily.
I hope this helps.
Vic
Posted on May 30, 2009
SOURCE: Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Posted on Sep 18, 2009
Why dishwasher started making growling sound all of a sudden?
Possibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Remove any debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hotrunning waterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.Loaddishes and re-check
Apr 09, 2012 | Maytag Dishwashers
At the start up of the wash cycle and then periodically thru out other cycles after there is a noise that sounds between grinding and what "air bound" lines sound like. this was minor in the early life and...
Try tearing the lower spray arm assembly down to the deck (making notes to record placement and orientation of all parts as you go along). Clean the filter screens in hot water, detergent, and white vinegar. Remove the pump components at the very bottom (not the motor itself) and look for debris in the impeller chamber. Check the holes in the deck for food debris. Assemble in reverse order. Check the spray arms for plugged spray holes and any split seams. Hope this helps!
Jul 25, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
IT is leaving food on the dishes
You do not have to prewash your dishes before loading them. In fact, by prewashing, you actually defeat the purpose of most dishwasher detergents. These detergents are activated by the grease and oils in food and work better. You should only scrape your plates of solid materials that are not recommended to go into a dishwasher (i.e., celery, popcorn kernels, tough chunks of meat, gristle, etc.).
If you are getting food particles on your dishes, this is known as "redeposition". Most commonly it is caused by food particles trapped in the filter of the main wash pump. You will need to remove the lower spray arm and access the filter screens and clean them of all debris.
If you need further assistance on how to disassemble your dishwasher to access the filter, please post back with your MODEL NUMBER. I hope this information is helpful to you.
Mar 29, 2010 | Dishwashers
KitchenAid Dishwasher (model KUDS01IJBL) has black gunk inside
That black gunk is caused by soap deposits and food particles that do not get washed down the drain. This all collects in the area around the door gasket and front of the wash tub and forms a sticky black sludge. You need to periodically clean the interior of the dishwasher out with a non-abrasive cleaner with some bleach in it to kill bacteria. You should also check the wash pump sump (located under the lower spray arm) to make sure it is not being clogged with food and debris. In order to access the pump sump, you will need to perform the following:
1. Remove the lower wash rack and lower spray arm.
2. Remove the upper wash rack and spray arm.
3. Locate the screws holding in the upper spray feed tube. Remove the screws to the feed tube and turn the whole assembly 1/4 turn to the right (CW direction). The entire assembly will unlock from the wash pump assembly and lift out.
4. Remove the strainer assembly (known as an accumulator) that covers the pump sump area.
Inspect the sump area for food particles and debris that may be contributing to the mess inside the wash tub. If you need some guidance, pcappliancerepair.com has some very helpful exploded view diagrams to assist you.
If you have any questions, or require further assistance, please let me know. I hope this is helpful to you.
Aug 17, 2009 | Dishwashers
Top tray of Kenmore Quietguard3 dishwasher not cleaning!
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Apr 03, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwaher does not clean, upper rack
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher not cleaning
You don't have to because the door will be open, but if you feel more comfortable shutting off the power to the dishwasher, do so.
Mar 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirpool Quiet Partner III, and the top layer of glasses is not getting clean. I had a technichian out some time ago, and the problrem was caused by food debris trppaed in the filter in the wash...
CHECK THE SPRAY ARM HOLES,ARE THEY CLOGGED ??IF THERE NOT YOU MAY NEED THE PUMP REPLACED (NO PRESSURE).........BY THE WAY THE POWER DRIVE UNIT IS NOW REFERED TO AS A > MOTOR/PUMP WHICH IS NOT INCLUDING THE PUMP.IT'S THERE WAY OF ADDING CONFUSION WHEN WE ORDER PARTS. 1ST LOOK FOR CLOGGED SPRAY ARMS. LEAVE A RATING !!
Jun 08, 2008 | Whirlpool Dishwashers
Maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Jul 31, 2007 | Jet Tech Systems STEALTH Dishwasher
My Bosch Dishwasher doesn't clean
open the door while in the wash cycle and check water is spraying from the spray arms and that the spray arms are rotating. get back to me with the results and i'll try to give some guidance
May 04, 2007 | Bosch 24 in. SGI43E05GB Built-in...
Maytag MDB7100AWB Dishwasher Logo
53 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
