Question about Canon PIXMA MP150 All-In-One InkJet Printer
Black ink low, error message 5200
Changed black ink cartridge and turned off computer but still isn't resetting error code. When I opened the copier to put in the ink cartridge, usually the ink cartridges will slide over in order to reach them. I had to manually move them because they weren't doing it automatically.
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
Canon pixma mp272 printer. replaced black cartridge for the first time and now it wont print. getting error p08 on the printer and error 5200 on my laptop screen
Hello Hellen,
the error P08 is error for abnormal temperature in print head. Aa possible cause the ink cartridge is faulty and needs to be replaced.The same error description is for 5200 on your PC.
I recommend that you try to replace ink cartrigde under warranty in store where you bought it. If after that you still have error, take the printer to the service center because they logic board ( pcb ) is faulty.
Hope that helps!
Aug 25, 2011 | Canon Pixma MP270 All-in-One InkJet...
We have just put a new black ink cartridge in our printer and now it won't print. The computer says it is error# 5200 and to see the user guide. The manuals don;t have any info to help. I have tried...
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
Jul 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hello. My Printer is Canon Pixma MP280. In the LED it says the error code P, 0, 8. I don't know how to fix it. I tried to press the Stop/Reset button for 10 seconds twice but it doen't fix the problem....
Mine had the same error message and it appeared right after I filled my cartridge up. (go figure) I turned it off and then on, took the ink cartridge out, (black) reinserted it and then scanned something. It printed out and the message is gone. I've yet to actually print from the computer yet but my guess is that it's going to work.
May 01, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Black cartridge is new. registers low ink level and does not print at all.
Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
black = black side(left) color = color side(right)
photo cartridge = black side(left color = color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to purchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
Rick
Mar 17, 2011 | Dell 962 Photo All-In-One InkJet Printer
Canon mp270 error code 5200
Hello and WelcomeError 5200 is a service error. Follow this solution step by step
  1. With the printer turned on,unplug it
  2. Open the top and bring the ink cartridge holder to the middle
  3. Raise the gray bar and remove the print head assembly with the cartridges in it
  4. Lower the gray bar with the head missing and close the top with the head out
  5. Restore the power,wait till the printer starts
  6. It will tell you to put in the cartridges, Put in the cartridge
  7. Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then
Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Please rate my solution as Four Thumbs if it was helpful. Thank you for using FixYa
Mar 10, 2011 | Canon Pixma MP270 All-in-One InkJet...
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
Printer wont print (colured ink low) canon ip1600
TYPE IN ON ADDRESS BAR OR MENU
CANON PIXMA IP1600 PRINT ERROR 5200
ENTER
ROD
Feb 09, 2009 | Canon PIXMA iP1600 Printer
Error 5200
my printer is not working. its showing error(5200).what can i do to solve this problem.
Dec 08, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
104 people viewed this question
old marine
old marine
