Question about Rheem 42VP50FW 50 GallonNatural Gas Water Heater
No led lights - Rheem 42VP50FW 50 GallonNatural Gas Water Heater
  • Rheem Master
  • 5,089 Answers
Copy following link for troubleshoot by type of gas control.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Posted on Nov 09, 2012
Why does my everhot heat pump have a solid red led?
There is such a thing as the light is simply telling you the heater is on and working. Is it? If not, the light is saying so. Different machines use lights in different ways. Be blessed.
Jun 23, 2014 | Water Heaters
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
The pilot went out and I followed the lighting instructions and still won't light. The led light is also out and not flashing.
its the thermal coupling that needs replaced. if it goes bad it will shut the gas down as a safety feature. so if it will not light replce coupling. have a good one !
Apr 24, 2011 | Honeywell Water Heaters
Code 991 continues to show.. will not clear... how do we clear that code???
to clear the 991 Takagi code, simultaneously press the bottom 2 grey buttons of the four just to the left of the flashing LED light. When the LED stops flashing, release and then press the reset button on the black panel about 8 inches above that
Jan 17, 2011 | RTO Takagi T-M1 Mobius Gas Tankless Water...
Just bought a water heater with electronic lighter,will not light
check comp board for led light and a reset on board ??? LED will also flash and give code with problem look for code on door panel or close bt and fallow instructions????
Oct 20, 2010 | Rheem 81VP6S/430126 Water Heater
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Rheem 42VP50FW 50 GallonNatural Gas Water Heater Logo
51 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
