Question about Oster 3200 Inspire In2itive Food Processor
Can I make dough without a dough blade - Oster 3200 Inspire In2itive Food Processor
How do I get a dough blade for kitchenAid food processor Model 4KFP 600 WH
Kitchen Aid list them, it's on this page called blade, dough
http://www.kitchenaidpartsonline.com/modellookup/index/thirdstep/keyword/KFP600/model_no/KFP600WH/model_id/398686/diagram_id/10083552
Feb 24, 2015 | KitchenAid Food Processors
Hi there, my dough blade won't come out from my fp2500mc wide-mouth food processor. Is there's anything that I can do. I've tried everything but it won't come out
i have had this same problem and unfortunately it seems that the disc stem gets so hot that it melts the top of the bowl to the blade. I finally got it out but the bowl was ruined as was the dough blade.
Mar 17, 2011 | Black & Decker Food Processors
My 12 cup kitchen aid food processor dough blade is seriously stuck inside the bowl after I made some dough. How do I get it out?
Dough is normally water soluble. Try soaking it in water for a several days up to a week. Then try prying it loose.
Sep 17, 2009 | KitchenAid Food Processors
Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Apr 08, 2009 | Black & Decker Food Processors
Blade holding disc for Breville Food Processor Model No. FP7/FP8 Replacement required. Phone numbers required for contact.
Hi. I'm a Breville Service Centre.
No new parts for FP7 or FP8 are available, your best bet is to check out garage sales or you local Salvos/St Vinnies etc as people may sell their odd pieces once their motor dies. Which is rare because they were good machines!
Mar 18, 2009 | Food Processors
Motor fails to operate - very hit and miss
Make sure you are using the dough blade for dough instead of the regular blade - dough will cause the regular blade/assembly to gum up. This is actually a VERY high quality unit w/ a 20-year motor warranty. I would see if you get better results with the dough blade. Don't give up on it yet.
Dec 14, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Dec 27, 2007 | Cuisinart DLC-5 Food Processor
Making Dough
Yes, it is the S-blade. I can't find my manual either and I have been trying to figure out how to get it onto the shaft!! The Hamilton Beach website says it should slip down the shaft once the bowl is attached, but I have a white piece on top of the metal I can not remove and the s-blade will not slip over it.
Dec 03, 2007 | Hamilton Beach Chefprep 70700 Food...
Oster 3200 Inspire In2itive Food Processor Logo
Top Oster Food Processors Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
David Ellis Rhea
Are you an Oster Food Processor Expert? Answer questions, earn points and help others
