Question about Sharp Projector Lamp For Xv-z90 Xv-z90e Xv-z90u Xvz90e
Sharp projector Bulb replaced but still won't work?
Switch projector on, power led green, lamp led green n flashing,fan on, no lamp light, then both led's solid red, fan off. Bought new lamp and does the same thing?! HELP
  • wmaskinner
    wmaskinner Nov 10, 2012
    When I say 'switch on' I mean at the wall, not on the proj' itsself.
    An user who is expert in 3 categories / brands.
  • 729 Answers
Check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Posted on Sep 18, 2016
  • 4 Answers
SOURCE: sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Posted on Apr 19, 2008
  • 150 Answers
SOURCE: Recently I was using my xv-z90u, I started the
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
Posted on Jan 17, 2010
  • 150 Answers
SOURCE: I bought a new lamp for my sharp XR-11XC.
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
Testimonial: "Thanks, it works after reset."
  • 23 Answers
SOURCE: I have the Sharp XV-z90u and we just replaced the
Or you could test it with just a burner which would be even cheaper. LumenArc sell burners individually. Your problem could be a ballast as well.
Posted on Jan 21, 2010
  • 699 Answers
SOURCE: I have a sharp xr-10x
The bulb is trying to light but fails.
I would suggest you remove the bulb and check the connections are ok.
Make sure when you put it back it is in firmly.
Also while you are at it check and clean all the filters as they are often forgotten.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 18, 2011
Lamp keeps cycling on and off.
the circuit is closed somewhere it shouldnt be
Apr 13, 2013 | Sharp XR-10X Multimedia Projector
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Jul 06, 2009 | Sharp XR-1S Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Nov 20, 2008 | Mitsubishi LVP-X80U Multimedia Projector
Sharp Projector Lamp For Xv-z90 Xv-z90e Xv-z90u Xvz90e Logo
107 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
