Question about Sewing Machines
Thread balling up at start
Bobbing is nesting at start
  • Sewing Machines Master
  • 7,365 Answers
Make sure the thread has not come off the thread take up lever
try a new needle
make sure the bobbin is turned the right way and inserted the right
way in the bobbin case
make sure the bobbin is not over full
make sure the bobbin is not warped
Posted on Nov 09, 2012
bargainbox
  • 1388 Answers
SOURCE: why does thread nest form?
To read about the reasons and solutions to this looping on the underside...........start here.........and as allmakes says, ensure correct threading through tension dial.
Posted on Feb 17, 2008
SOURCE: breaking needles bobbing in huge ball and thread not even
i cleaned and oiled it and it fixed itself.
Posted on Nov 16, 2008
  • 492 Answers
SOURCE: bobbing thread not picking
Try this:
Machines Support
For questions regarding Machine Support, fill out the Machines Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 774.
Technical Support
For questions regarding Technical Support, installing, updating, or using your embroidery software, fill out the Software Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 775.
General Inquiries
For general questions, please use the General Inquiries Form.
Request a Machine BrochureFill out the Brochure Request Form to request a brochure for your choice of machine.
Janome Mailing List
Click here to join the Janome Mailing List.
Posted on Apr 30, 2009
graemevm
  • 519 Answers
SOURCE: Bobbing thread not picking
Make sure you have threaded the bobbin thread correctly. Also your top thread must be correctly threaded in order to pick up the bobbin thread.
Please let me know if I can help any further.
Best wishes,
Graemevm
Posted on May 01, 2009
SOURCE: How do I keep bobbing thread from bunching on model 375?
You can get a PDF manual for this model on the Euro Pro website, to show you how to thread correctly and more
Posted on Jul 06, 2009
The thread balls up on the bottom side, it looks like the foot is not moving the material
Frequently, the top thread is not seated in the top tension disk and it is causing thread nesting (or bird nesting).
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Re-test your machine.
It may help to install a brand needle.
Also, avoid old or bargain bin thread.
If the mess is under the fabric, the issue is the top thread.
Jul 27, 2017 | Sewing Machines
Elma supermatic balls up under machine after a few stiches
Thread nests (also called bird nests).
Remove the top thread.
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Apr 23, 2017 | Sewing Machines
Consew machine. My bottom thread has ball knots on the bottom. I have changed the needle and the top stitch is perfect. Please advise.
Re-check the thread that is knotted. It's most likely the top thread causing what is called thread nesting or what I term "thread barfs."
Thread problems appearing on the top of the fabric are generally caused by the bobbin thread. Problems appearing under the fabric are usually a result of upper thread issues.
Set the upper tension to the midway point.
http://www.superiorthreads.com/blog/2015/8/what-causes-bird-nests/
Apr 19, 2017 | Consew Sewing Machines
When i first start sewing the thread will bunch up and make a rats nest how do i stop thisa
That is called thread nesting or bird nesting--or what I like to call thread "barfs."
Be sure to ALWAYS RAISE the presser foot when threading the top thread. This releases the tension disk so the thread will seat completely.
Bring the bobbin thread to the top of the fabric and gently hold both thread tails in your left hand while taking the first stitch or two. It may be beneficial to manually turn the handwheel for the first couple of stitches. It also helps to have the take-up lever at it's highest point BEFORE starting to stitch.
Sewing Machine Thread Bunching Up Here Why
How and Why to Bring up the Bobbin Thread
Apr 01, 2017 | Sewing Machines
How to fit my bobbing casing?
Use your hand wheel and turn it. Monitor under the throat plate. The part you see moving will eventually show an opening. Stop there and install your bobbin casing. If it has a little metal piece across you will have to lift it slightly. After it is snug you can install the bobbin.
Mar 20, 2015 | Sewing Machines
How can I fix this problem on the Necchi sewing
That bird's nest of a jam is very frustrating! Here are a few checks to make.
1. Ensure that the upper thread is threaded correctly, that is, that all the guides are engaged in the correct sequence.
2. Ensure that the upper thread is firmly settled between the tension discs and in the take-up lever.
3. Double check that he needle is inserted correctly.
4. Ensure that the bobbin is inserted correctly ... the thread is spooling off in the correct direction. This is very important.
5. Ensure that the bobbing thread is locked in the tension spring.
6. Make sure that the presser foot is in the down position as you begin stitching.
Oct 12, 2014 | Sewing Machines
Bobbin case for 7462 singer how do u put in the machine
Open Up The Door Below The sewing Foot. Lift Lever And Then Pull Out the Bobbing Case Replace Bobbing And Put Back Together
Feb 02, 2014 | Singer 7462 Mechanical Sewing Machine
Omega sewing machine bobbing wont catch
Take a look at these 4 images (Click each one to Zoom)
Sewing Machine Hook Timing
Very good chance your Timing is slightly out, often after a jam or sewing heavy fabrics...
Not an easy home fix without a Workshop Manual
Jan 14, 2014 | Omega Sewing Machines
Nesting at startup sewing machine
try using a new needle--make sure it's the right one for the fabric
your sewing
try rethreading the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
check to see the thread has come off the thread take up lever
check with brother customer service about oiling the machine
some you oil and some are self oiling
Nov 08, 2012 | Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
