Question about AT&T Lands Phones
AT&T Key buttons not working - AT&T Lands Phones
  • AT&T Master
  • 14,641 Answers
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Posted on Nov 09, 2012
I am trying to connect a wireless ready Samsung blueray player to my Motorola Surfboad and it says to press the wps button on the surfboad, where is it?
NOTE: [] & "button(s)" represent features on the remote controller. {} & "key(s)" represent features in on-screen menus.
ROUTER INFO: WPS is on the SBG901.
BLU-RAY DISK PLAYER: You did not mention the model # of the Samsung Blu-ray disc player, so this information is somewhat generalized.
PREREQUISITE: Once you have attached Samsung's proprietary wireless adapter to that Blu-ray player, have connected that Blu-ray player to your TV, & have powered on that router & Blu-ray player & TV, access that Blu-ray player's initial settings menu.
STEP ONE: From the Home menu, press ?? buttons to select "Settings." Press [ENTER].
STEP TWO: Press ?? buttons to select "Network." Press [ENTER].
STEP THREE: Press ?? buttons to select "Network Settings." Press [ENTER].
STEP FOUR: Press ?? buttons to select "Network Type." Press [ENTER].
STEP FIVE: Instead of using the the "PBC (WPS)" selection, press ?? buttons to choose the "Wireless" selection & press [ENTER].
STEP SIX: Press ?? buttons to select "Internet Protocol Setup." Press [ENTER].
STEP SEVEN: Press ?? buttons to select "Auto" or "Manual." Press [ENTER].
IF SETTING UP WIRELESS CONNECTIVITY VIA AUTO NETWORK SEARCH: If you selected "Auto," press the ? button to go to "Access Point Selection." Press [ENTER]. Upon searching for available wireless networks, it will display those choices in a list.
A.) In the list of networks, press ?? buttons to select your network. Press [ENTER].
B.) IF "PIN/Security" DOES NOT POP UP, THEN SKIP THIS STEP; otherwise, press ?? buttons to select PIN or Security (Security Key--the usual option), & enter your network's Pass Phrase on the Security screen. (This Pass Phrase would be what you would use to access the network. IT SHOULD NOT THE PASSWORD WITH WHICH YOU SET UP YOUR ROUTER!)
Press number buttons on the remote to enter Pass Phrase numbers OR use arrow buttons on the remote to move from key to key in the Security Key screen. Change the type of on-screen accessible characters by moving to the on-screen {a/A/1/?} key & pressing [ENTER] on the remote. (The character set changes with each press of [ENTER]. Once displayed on the screen, you can enter a letter by pressing the number button on the remote which corresponds to that letter key. Pressing that button repeatedly changes the letter. You can move to {Delete} & press [ENTER] in order to remove the last character entered. You can move to {Clear} & press [ENTER] to clear all entered characters (or just press the red [(A)] button. When done, press the yellow [(C)} button (or the {Done} key followed by [ENTER]).
C.) WAIT UNTIL THE CONNECTION CONFIRMATION MESSAGE DISPLAYS & THEN PRESS [ENTER]. You're back at the Network Selection menu.
D.) To test the connection, press ? to select "Network Test." Press [ENTER].
IF YOU REQUIRE ASSISTANCE WITH SETTING UP THE WIRELESS NETWORK CONNECTION MANUALLY, I SUGGEST THAT YOU READ THE MANUAL (http://www.samsung.com/us/support/).
Jan 08, 2011 | Arris SURFboard SBG900 Wireless Router...
Alarm not working proper
try this. lock car door with key and hold key over for 30 secs then unlock the car with the remote holding button down for 30 secs.assuming the battery in the remote is okay...it should reset the alarm system.
Mar 08, 2010 | 2003 Ford F150 Regular Cab
Screen going blank.switches off.
steps to copy phone to sim
- press down soft key once
- then press up key two times & select button
- then again press up once & select button
- then press down key 5 times & then select 3 times
- wait for 2-5 mins your phone contacts will be copied to sim
vote me if u get this
Jan 04, 2010 | Sony Ericsson K850i Mobile Phone
Remote starter does not work after the battery change. How to reprogram it? Audiovox ID:BGAAV2TF
Turn key on and press valet button 3 times then press butoon on remote.Turn key of and thats it
Nov 14, 2009 | Car APS921 Remote Starter - Keyless Entry
How to I reset my keyless 2005 toyota prius? I recently brought my car to a collision shop to change my driver's side door. They told me they unplug the battery cable. In doing this, now my keyless does...
KEYLESS REMOTE PROGRAMMING
1- Driver's door open & unlocked. Key out of ignition
2- Insert & remove key 2 times within 5 seconds
3- Close & open drivers door twice within 40 seconds
4- Insert key into ignition & remove
5- Close & open drivers door twice within 40 seconds
6- Insert key into ignition
7- Close the door
8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK"
- ONCE for ADD mode
- TWICE for REWRITE mode
9- Remove the key from ignition
10- To confirm your mode selection, the power locks will now cycle "lock" to
"unlock" a number of times corresponding to your key cycles in step 8
11- Within 40 seconds of confirmation
- Press both transmitter Lock & Ulock buttons simultaneously
- Within 3 seconds press transmitter Lock button for more than 1 second
- If successful, the power locks will cycle once (twice indicates
transmitter problems)
- Repeat step 11 for additional remotes
12- Open door to exit programming.
Jan 18, 2018 | 2005 Toyota Prius
Key fob wont work on my Peugeot Expert
Does the battery need changing on the key fob?
you can check by using you'r mobile phone cam & pointing the key fob (ultra violet bulb) at the lens when pressing the button, you should see the light flashing on the key fob looking through the camera, you can use any camera, most of them will see the light as it's out of our sight range but cameras pick it up.
If not then unscrew the key fob & split it carefully (use an old credit card not a knife or screwdriver) & change the battery.
If the fob work's then the problem is with the receiver, usually up by the rear view mirror.
Hope this help's !
Sep 21, 2009 | 2005 Peugeot 405
HP C6180 INKSYSTEM FAILURE 0xc18a0201
Perform the following steps...
A. - Press and hold the �*� key.
B. - Press the �#� key and release both keys.
Display should say �Enter Special Key Combo�
C. - Press and release in sequence the �1�, �2� and �3� buttons.
screen says "support" R0631M
Press and release the right arrow button until the display says �System Configuration Menu�.
Press and release the �OK� button.
Display should say �Hardware failure status�. If not there already, Arrow Key over to �Hardware failure status�,
Display should say �Hardware failure status: Clear. Press OK to clear�.
Press and release the �OK� Button. Message changes to �Hardware failure status Cleared. Press Cancel to continue�.
Press and release the �CANCEL� button as many times as necessary, so that, either the �Welcome to Photosmart Express� screen appears, or, the �Ink System Failure� screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE!!!
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message �USE POWER BUTTON TO SHUTDOWN THE PRINTER� followed by �PRESS OK TO CONTINUE�.
Press OK.
The Printer will start the �ONE TIME INK INITIALIZATION PROCESS�. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page (may or may not print the diagnostic page).
At this point the error should be cleared and you can now print a test page. If the error message still being displayed on the printer, your printer will require service/replacement.
I hope this works for you!
Aug 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Honda civic 2008 - panic button on the key
Placed jumper cables on the car to try & jump alarm sounded pressed the unlock button & was then able to start car without any problems.
Mar 12, 2009 | 2008 Honda Civic
OSD Lock Problem
I have a hanns g 22" widepanel , I had the same problem with lockout. I had my monitor disc and looked on it, or in a manual if you still have it. Here is the combination I had to press and it worked. I pressed the arrow buttons and the menu button all together a few times and it unlocked. Try that!
Function Key Lock:
Press the <「Volume -」, >「Volume +」and the 「Menu」buttons simultaneously to
enable the Function Key Lock. When the Function Key Lock is enabled, only the Power
button is active. Press the <「Volume -」, >「Volume +」and the 「Menu」buttons
simultaneously again to unlock the function keys.
Aug 03, 2008 | Hannspree HW191D LCD Monitor
Lands Phones Logo
Top AT&T Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
