Back to:
Tags:
Fuji FinePix S7000 Digital Camera
Seems like color is drawn out (by 2 users)
posted by Maranda on May 23, 2007
I can go to take a pic and the screen is blurred and when I take a picture that looks "ok" it is like the color is drawn out of the picture making it blurry. I have new batteries and a new xd card. Any ideas would be greatly appreciated.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by riegjr15, posted on Feb 13, 2008
Whenever my camera is on or while taking a picture, it seems to be a little bit blurry. It was never like this, and one day it just happened. I attempted to make sure all the settings are right, but I can't find my manual. Help!
Solution #1
posted on Dec 23, 2007
Not Rated (0)
t00nz
Rank:Guru Guru
Rating: 90%, 994 votes
Know this post is old, but it may help others with a similar problem. This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=839010&prodcat=2147483647&sscucatid=664262&quicklink=true
Applicable cameras include:
F303, F410, and F700
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Seems like color is drawn out:
I don't want to Accept this solution
Solution #2
posted on May 24, 2007
Not Rated (0)
jackboy
Rank:Wiz Wiz
Rating: 77%, 3707 votes
Thrck that you have the setting correctly set up
You may have inadvertently set it to Marco or Low light setting giving long exposure time.
Run through all the setting as in the manual.
If no result- contact the Fuji Tech support Team on the web address
Thank You!
Can you Help with these Digital Cameras problems?
LCD screen on the FinePix S700 is damaged. Does anyone...
when i take a photo the top half is white but video seems...
bbbbbb
Is there a way to download the original software that is...
when i turn on my camera zoom error msg will shown,and i...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
