Question about ASUS X44H-BD2GS 14in Laptop i3 2.2GHz 4GB 500GB DVDRW
I can find no way to turn off the touchpad and it's screwing up all my papers
    Problem Solver:
  • 11 Answers
I am assuming that you are accidently bumping your touchpad while typing. There are several programs out there to correct this issue, but the easiest one i have found is called TouchFreeze. It disables the touchpad whenever your are typing.
D/L link: http://code.google.com/p/touchfreeze/downloads/detail?name=TouchFreeze-1.1.0.msi
Posted on Nov 12, 2012
My printer is i-sensys MF4150. It prints one page then stops the error light flashes red and message 'load correct paper cassette : ltr ' appears on the LCD screen.I print 1 page then I...
Dear
Pl. select the paper size ( as mentioned on the paper packet) on computer on click START-PRINTER AND FAXES(new window opened)-(right click on printer icon) PRINTING PREFERENCE(new window opened)-select PAPER -paper option (here the paper size to be selected- APPLY. This may set the paper size default.
Thanks.
Feb 03, 2015 | Office Equipment & Supplies
Hi. I inherited a 1998 Husqvarna 265 rx. Got new plug and new fuel and it fires ok. Wouldn't stop so I added a washer under the 'earth' screw and it now stops. Problem is poor acceleration
To set the throttle, start by slackening the cross head screw securing the cable in the handle and pull completly out, now slacked the three allen headed screws securing the handle, twist the handle to the best position for your use ( at full throttle your thumb should not be straining ) now slacken the lower cross head screw and turn the silver clamp to tention the spring underneath, when correctly adjusted the throttle trigger should spring back to the idle position readily, now re fit the cable up through the clamp, turn the cable so as it is just about to open the carb throttle spindle, lock the cross head screw and test to make sure you are getting full throttle, if not slacken the screw and turn cable a little more.
Sep 19, 2012 | Husqvarna 531004054 Throttle Wire
Does Craftsman Model 917.272461 have a low oil shut down sensor?
Sounds you added oil for late. Can you turn engine by turning engine
on the screen, top of engine?
Aug 26, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Weiser lock manuals
The direct link to the PDF file of the installation & programming for the Powerbolt:
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Mar 14, 2012 | Weiser Lock GED1460X GED1460X11P Venetian...
Tray lifts to meet the rollers then drops back down. Error message 'No page was found in the feeder'
Clean the 'black dot' in the centre of the paper tray. There is an optical sensor under that. The tray will lift even without paper, but will go back immediately.
If the scanner stops after 3 pages, check disk space in your computer. If you are scanning in TIFF uncompressed, it takes lot of space. For color and Grey try JPG format, for mono TIFF G4 is the ideal option.
S. Mohan, Chennai, India
Mar 02, 2012 | Canon DR-9080C Path-Through Scanner
Error 51.23 after paper jam
**Yellow laser scanner error, replace scanner assem..For tech guys: Remove scanner assembly, remove cover,check for yellow scanner motor rotation. if its hard or struck, gently remove engine motor,lubricate the shaft fix it back & verify rotation, how ever entire unit opened clean all reflector glasses with ear buds gently, fix the unit back properly.(out of four screws, factory wont fit one or two screws for alignment match, same way fix the screws, don't inter change). check for print if its rectified. process end..or else replace scanner assm..
Dec 21, 2011 | HP LaserJet CM1015 All-In-One Printer
My brother mfc 440cn had a paper jam & after i removed the paper "unable to print 50" & "unable to print 30" showed on the screen. i went to brother web site & went to the...
You have to open the printer and set it back into the ph carrier.
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees 2) make a note of where each connector goes 3) release the Ribbon and 3 Multicolor cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees. 4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.5) Remove front panel by disconnecting ribbon and wiring on both sides.6) Remove 6 Screws (2 on back, three at front and one middle right7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.8) Re-Seat Encoder Strip.9) Re-assemble in reverse.
Nov 08, 2011 | Brother MFC-440CN InkJet Printer
Touchped not working
What is the complete model # on the sticker inside the microwave?
Oct 11, 2007 | Kenmore 63252 Microwave Oven
ASUS X44H-BD2GS 14in Laptop i3 2.2GHz 4GB 500GB DVDRW Logo
43 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
