PC not POST - Phase LEDs blink once then nothing
Recently moved my PC out of an old case and into a new one, replugged everything as usual and attempted to start up but nothing happened. The four Phase LED's on the motherboard flash once but neither the fan on the PSU or on the motherboard spin up and there is no further activity. I've unplugged and removed my HD's & video card and tried troubleshoot that way but am getting the same result. Any suggestions? I'm guessing it's a PSU issue but I've no way of testing that without purchasing a new one.
  • hugh Nov 14, 2012
    So I've managed to get some form of boot - it looks like the PC is booting normally but after about three minutes it shuts down again. Any suggestions?
  • 2,878 Answers
Try testing with a voltmeter. They are common, cheap, and you may even have one. Or, at least be able to borrow one.
Posted on Nov 09, 2012
  • hugh Nov 14, 2012
4 Suggested Answers
  • 176 Answers
SOURCE: MSI K8N NEO2 Platinum NOT Posting + No beep + No display
try to test the CPU on another machine ...
or at least remove it and reinsert it.
But if u say that u reseted the BIOS an it still not doing the post, it just could be that the motherboard is out !
It can also be the PSU as u say, but i doubd it ! Try to remove all hard drives, cdroms, etc... to limit the power usage... and see if it passes the post.
U can also try to remove the motherboard from the computer case and put it on an insolating surface and than try to boot (sometimes shorts appeare betwen the motherbord- case - psu)
Posted on Jan 08, 2009
  • 17 Answers
SOURCE: Abit AN7 motherboard does not boot - POST code AF
I think is a bios problem, a ram failiure would be C1 post code.If the bios is corrupted, try a blind bios update or if it doesn't want to, you must do a hot flash update.For more details google search for award bios hot flash.Or dump it and buy a new one.Usually when the post doesn't change at all or if it stops to 90 is a bios problem.I had a similar problem, mine hang at 90-after a complete check of uguru.In your case might also be the uguru chip.I hot flashed the bios.I used an abit nf7s 2.0 to start and then put in my bios.It worked and i also made a backup.Your chip is Winbond-4 mb capacity.
Posted on Jul 11, 2009
  • 10 Answers
SOURCE: No onboard video with my new MCP6P M2+ mainboard
Try removing the bios battery for 30 seconds then boot the pc, this will clear the bios. Maybe the bios was misconfigured. Else you can jump the "clear cmos" pins on your motherboard, same affect as removing the battery. If that doesn't work try different ram, it's possible the ram is not compatible. Sounds plausible being that there were no post beeps. Good luck.
Posted on Sep 14, 2009
Nikon D90. blinking "clock" sign in the top LCD panel. Any advise?
Sounds like you may have a circuit failure. Possibly the phase switch but that is not the usual symptom. In any case this should be sent to Nikon as they stopped selling parts a year ago, and also you need their proprietary software to initialize a new board if it is replaced.
Jun 13, 2014 | Nikon DSLR D90 Digital Camera
Motherboard blinks once
hi
try another power supply
then check m.b if not working contact the vendor may be it failed
Dec 19, 2013 | Computers & Internet
General system board failure The LEDs near Caps
Your laptop has an external vga card
Thats usually the first suspect
Try reheating the one you have and if that works, even for a little while,look for a replacement
Sep 01, 2013 | HEWLETT-PACKARD EliteBook 8540w (FN095UT)...
My hp pavillion dv7 keyboard lock lights keep flashing; at one point the computer didn't want to boot up; I finally got that up today after six months. But the cap lock and the number lock lights still...
those are POST code, error codes, you need to watch time and count them. report them.
leave the battery main out.
does it run ok now? yes/no.? main battery out?.
even new cheap batteries fail easy and hard and short out.
test it with no main battery. it can run on AC power for ever.
are you going to run the COIN cell RTC battery for 10 more years.
it wont make it..
this PC is 10 years old today (can be) so is RTC battery end of life. most fail in 5 to 7 years, says the pink bunny. (and is correct)
the manual shows how to replace it at the real HP Site,
fixya is not hp, not at all.
page 63 shows the way to the RTC
http://h10032.www1.hp.com/ctg/Manual/c01918142
if you power on the PC, and hammer the f10 key]
BIOS runs, its menus;
check the time and date here, if wrong the RTC battery is dead.
read page 3 how.
http://h10032.www1.hp.com/ctg/Manual/c01662442
  • old PC have many points of failure (endless it seems)
  • does the fan run? is it packed in lint, as all are this old.?
  • causing it to overheat?
  • RTC coin cell bad.
  • main battery bad. (just leave it out until the PC runs right again)
  • power pack wires broken, or running real hot.
  • HDD going bad,
  • windows infected?, no OS stated but avoid XP.
HP caps lock POST blink code page is a horror of horrors
no 2008 listing, to name one flaw (2011 and newer sadly)
https://support.hp.com/us-en/product/hp-pavilion-dv7-1100-entertainment-notebook-pc-series/3756677/model/3807256/document/c01732674
here is a old post at HP, one guy 3 year ago said
LEDs blink 1 time
CPU
CPU not functional
LEDs blink 2 times
BIOS
BIOS corruption failure (RTC coin cell dead)
LEDs blink 3 times
Memory
Module error not functional
LEDs blink 4 times
Graphics
Graphics controller not functional
LEDs blink 5 times (or RTC dead)
System board
LEDs blink 6 times (or RTC battery dead)
BIOS
BIOS authentication failure
Feb 15, 2018 | HP Pavilion dv7-1132nr Notebook PC
Ga-h55m-s2h board not booting, nothing on screen . cpu fan spins and everything is indicating activity. Post give 1 long beep and 2 quick. phase leds 1 and 2 green, 3 orange, 4 red
Just had the same problem, same board. This mb does not play well with all types of RAM. I had a single 2gb Patriot dimm and it did the exact same thing, removed the RAM and it would boot but no screen. Replaced the single dimm with 2 - 1gb dimms and it booted right up with no problem. Hope this helps.
Mar 10, 2010 | Gigabyte Computers & Internet
Shuttle X PC - HD + Power LEDs briefly illuminate, no boot.
It sounds like you have a bad power supply. It will store up a very small amount of energy (enough to run some LED lights) but not enough to power up the system. That's where I would look. If that is not the problem, then I would look to the capacitors on your motherboard. Good Luck!
Dec 02, 2008 | Shuttle Computers & Internet
Dell dimension 5100 - no power
It seems that your SMPS power supply may be having some fault...try to replace it...
Dec 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No video output
Do you get a single beep from the POST at start-up? That signifies that the internal check is OK.
Jun 27, 2008 | Computers & Internet
Unhibernating
you have to start doing a test on secuences first you have to make sure the power from the outlet to the end the cable it has 120 v ac if there is power you have to open the case to check the power suply output to the motherboard there is a power suply testers you can get that on fry'z electronics store i think thats where your problem is located power suply after you do this test post it back to see if does not fix the problem if does fix it leave your feedback
Jan 01, 2008 | Computers & Internet
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
