Question about Seiki SC323FI 32"lcd hdtv,720p,60hz,3-hdmi,1-usb,pc,1-component,1-comp
I am thinking it might be the Volume + button is stuck, but I can't seems to press just fine. I know it isn't the remote either because the batteries are not even in it at this point. I unplugged it and left it like that for a while thinking it might reset something but still nothing. If it is in fact the physical button how can I go about fixing it?
  • Seiki Master
  • 8,617 Answers
If its the button the front keyboard will need replacement. You can check the tact switch on that board. If the switch is working then the main board would be suspect.
Posted on Nov 09, 2012
Channel is stuck on my driveway
From the video, there is only a picture of a security feed. Please be specific as to model, type of equipment, description of problem and desired solution.
Oct 19, 2012 | Televison & Video
Television volume down button sticks.
spray windex or 409 on the button n press it as you spray it n around the button. Loosen the grime in and around the button.
Sep 24, 2012 | Magnavox 32MF369BF7 32 in. LCD TV
It's like the volume button is stuck
all tv sets with keyboards (controls) on the front or side use micro switches which the buttons engage--these are momentary switches=only supposed to work when pressed--they go bad in exactly the way you have described--cheap and after being pressed too hard will not disengage.
The way to prove this (by the way the switches have priority over the remote so it will not work if one is bad) is either access the vol up control and disable (unsolder the two pins) or test the switches with a ohm meter----
If the remote receiver is on same board as buttons/switches you are going to have to unsolder the offending vol button--if it is not you can usually disconnect the control board and set will again work with the remote.
either test/unsolder or have a shop do it.
If set works fine with vol disconnected just use the remote as you would likely have to replace the keyboard to correct it.
If you have the meter and are familiar with reading resistance let me know and I will tell you what to look for.
SD TECH
Apr 27, 2012 | Toshiba Ct-90302 Remote Control
Audio isn't working
ya know I hate to say it but I've done this before. check the mute button on your remote. I've accidently hit mine before and it took me several days to realize it. lol. if it's not that. check the volume of the set itself, then check the volume with the remote....I know these are weird things to check, but they do & have happened, to me. lol. good luck & God bless.
Mar 21, 2012 | LG Televison & Video
I have Aiwa TV MODEL No. TV-A219 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its
Hello
Check your remote control hanset for proper functioning. Get into this link to know more about the faults and repair to remote contorls.
http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
If remote control functions proeerly, the front panesl switches to be suspected. If any one mong the microswitches inside got strucked, all functions will be distrubed. it will be best to follow any more after replacing these microswitches. These switches can be located just behind the control panel of the tv, soldered diretly to a printed circuit board. You have to replace all of the at the same time. Just undolder one amoung them as as sample, when you go to buy for a new one.
If this also does not help you, repalce its memory IC. This IC can be located very near to the main system control IC, will have 8 solder terminals. A very small IC and wont cost more. Eventhough it is very small, function of it when the set works is great. Replace it. When you buy this IC, make a keen look on it number. It is very important when replacing this IC. All these components stated above, can be bought from most of the electronic spare part selling shops st your town. OK.
Feb 07, 2012 | Aiwa TV-S2011 20"
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
May 18, 2011 | Toshiba 32A33 32" TV
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
My volume button goes all the way up to the max and stays there and sometimes my mute won't work how do i fix the problem
It looks as if your volume up button is stuck, either on the TVs manual buttons or the volume up button from the remote. To check if it's the remote, put the remote away from the TV, either in a drawer or take the batteries out. If the same check the Volume up button on the TV, it may be pressed down & stuck in this position. If this is ok most likely the volume button will be at fault & need replaced.
Jul 13, 2009 | GE 31GT660 TV
Volume Control not working via remote. Works manually. Is there a motor or belt involved that may require replacement?
Please check volume button works on remote? Take any digital camera / mobile phone camera and see remote front through camera and press volume buttons, if you see IR LED blinking then remote is fine and amp has problem with volume. Let me know exact model of Sony amp to see its schematics.
Jun 05, 2009 | Sony STR-DE935
Seiki SC323FI 32"lcd hdtv,720p,60hz,3-hdmi,1-usb,pc,1-component,1-comp Logo
22 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
