Question about Garden
Fuel mix for stihl FS 61 electronic - Garden
  • 8 Answers
SOURCE: What is the correct fuel mixture for this machine
Every Stihl I have ever touched requires 40:1 fuel mixture.
Posted on Jun 02, 2009
Dolfoff
  • 148 Answers
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Posted on Sep 26, 2009
john224
  • 1378 Answers
SOURCE: no manual, starting stihl fs 38 brushcutter
Here is the owner's manual.
Posted on Dec 17, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
rycgl
  • 1545 Answers
SOURCE: tuneup on stihl fs 250
If it has a Zama carb, then you can learn an awful lot be downloading their tech guide pdf file.. There is lots of info there and will help you greatly. The web address is: www.zamacarb.com/pdfs/TechGuide_2007.pdf
This will give you a better understanding of your carb and how it operates and has troubleshooting tips, etc.
Posted on Jul 10, 2010
My Stihl FS 36 will start but dies after few seconds. Have cleaned in-tank filter; replaced diaphragm but same problem exists. Could be tank breather but awkward to get at. Seems a fuel starve issue?
Hello Bob Breedon,
Big fan of STIHL... Check Fuel 50:1 mix ratio...!!
See owners manual:
Stihl FS 36 Instruction Manual Page 18
A very common mistake... is to use GASOLINE... and
forge to put in the 2-cycle oil...
As soon as the unit heats up... It will stop
(seize - in fact)...
Been there (forgot about that)
Carnac the Magnificent
Jan 16, 2018 | Stihl Garden
My Stihl FS85 runs good for about 20 seconds and then shuts completely off. I have replaced the Plug, cleaned out the fuel system and it still does the same thing. Could it be the coil?
Sounds like the main jet or the diaphrams in the carburetor are deteriorated. Remove carb and soak in a good carburetor dip style cleaner and rebuild with a new kit. Also replace the fuel line and filter and use a fresh gas mix.
Sep 17, 2012 | Stihl FS 85 Weed Eater
Why my stihl fs 250 not accelerate
Have you removed the chain brake.? Pull back the front 'black' hand guard to release the chain brake.
Jul 21, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
What is the oil to gas mix ratio ?:? stihl fs 45
If memory serves, Stihl recommends a 50 to 1 mix ratio on the gas mixture...( 2.6 oz oil to 1 gal fuel ) I usually run mine just a smidge richer and run a mix of 45 to 1... ( 2.8 oz oil to 1 gal of fuel ) I also add about 1/2 oz of "Stabil" fuel stabilizer to the mix (holds down gumming of the fuel and keeps things running sweet)...hope this helps... ;-D
Aug 08, 2010 | Garden
What is the propper oil mix for model 61 chainsaw?
Fuel/Oil mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Today most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 15, 2009 | Garden
What is the correct ratio gas to oil for my stihl fs 66 trimmer
Use a quality 2 cycle oil and mix it to the oil manufacturer's recommended ratio. Today it is usually 50:1.
Fuel in the USA contains ethanol; try to use up your mix in a month or less. HTH
Lou
Jul 28, 2009 | Garden
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Jun 02, 2009 | Garden
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
