Question about SanDisk Sansa e260 MP3 Player
Custom eq problem
When set to the custom eq, one side of the audio drops out every 3 or 4 songs. Turning it off/on again fixes it for just a few songs. Also, switching to a different eq setting (rock for example) and then immediately back to custom eq fixes it for a few more songs. Firmware is the latest version and all songs came from my CD collection. I have taken 2 e270 units back to Best Buy with this problem. Upgraded to the e280, same problem. Please see if you guys can recreate my issue on your units. thanks DenverTom
  • Bedrockblue Jun 20, 2008
    yeah, i have a similar problem... i was thinking it was something to do with my mp3 files since most of them were converted from wma files. The right of left channel will cut out. The lost channel will either crackle back to clarity after a few seconds or it will come back instantly once a new track starts.
  • 8,596 Answers
Contact Sansa tech support directly to inform
Posted on May 24, 2008
SOURCE:
How do I set the equalizer to my own custom settings on my RCA RS2635?
Hello
Press "Preset EQ" on the main unit, or "EQ" on the remote control to toggle among FLAT,ROCK,POP,JAZZ, CLASS. The display show the selection briefly. Press "Bass Boost" to turn ON/OFF boosting the bass frequency. OK.
Dec 03, 2010 | RCA RS2635 CD Shelf System
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Need help on setting custom EQ for my JVC KD R506 in car music system. m not able to find the settings. also any idea how to increase the bass effect from the speakers. can i connect a subwoofer without an...
Set your equalizer to you a V shape or U shape pattern, bass effect can only attain by adding a powered subwoofer, (amplifier and subwoofer). subwoofer without an amplifier doesn't sound good, your system doesn't have enough power to drive your subwoofer.
Jun 23, 2010 | Car Audio & Video
Sound Problem
Sounds like something's up with your EQ. From the main menu, go to Music>Music Options>Music EQ and try another setting or play around with Custom. Could also be volume. Go to main menu>Settings>Reset All (NOT FORMAT!!!) Recommend trying both in given order. Hope this helps.
Jan 06, 2010 | SanDisk Sansa Clip MP3 Player
Music EQ
Upgrading the firmware also has the same effect - Sansa never has and never will resolve this issue - sorry.
Oct 20, 2008 | SanDisk Sansa e250 MP3 Player
E.q.
If your songs are coming from more than one source, or you are using a pure file sharing program like Limewire, Morpheus, Frostwire, etc., every mp3 is recorded at different levels. You will have to become a bit of an audio editing expert to do this, but you will need to get audio editing software, and set the elvels, bit rate, etc of all of the songs to exactly the same level - or else, you will get variable play quality on your custom EQ settings. WARNING: This is going to take a LONG time.
-Tha Mp3 Doctor
Sep 02, 2008 | SanDisk Sansa e250 MP3 Player
I don't know how to use custom eq
press the EQ button until it says custom on the seting then press the tuner select button left or right and it will say bass or treble use the volume to turn it up or down then u got the bass control.:)
Feb 14, 2008 | RCA RS2652 Shelf System
VOLUME AND CUSTOM EQ OPTIONS AREN'T ON THE PLAYER! HELP!
download the newest firmware it will have custom eq =)
Feb 15, 2007 | SanDisk Sansa e250 MP3 Player
Custom soundtracks
It's amazing how great music can enhance any game, particularly action games. As the movie industry has known for about a century, music can make a bad video experience seem a lot better. Xbox is the only video game device that lets you add your own custom soundtracks to your favorite games. Here's how: Insert an audio CD into the Xbox optical drive. Access the Music menu from the Xbox dashboard display. Select Music > Audio CD > Copy, then choose the Copy menu. Select the tracks you want, using Play or Pause commands to audition songs. Choose Copy, and Xbox will store the songs on the hard disk. Then insert your game disc and load the songs using the game's setup menu. P.s Not all Xbox games support the custom soundtrack features, but many of the most popular ones do.
Nov 20, 2005 | Microsoft Xbox Console
Custom soundtracks
Nov 20, 2005 | Microsoft Xbox 360 Console
SanDisk Sansa e260 MP3 Player Logo
53 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
